Hey all.
i installed a drift bov today with plumb back or atmo i could choose either way but i choose atmo..
Since then its been running like crappolia..
Is there anything like a cpu upgrade or soemthing to fix the problem?Or is it just something i have to deal with
thanks
https://www.sau.com.au/forums/topic/178380-problems-after-installing-a-bov/
Hey all.
thanks
If its venting to atmo then you will run rich and your car will occasionally stall. Atmo BOVs on Skylines can be a bad mix. You can fix it up, DAFS.
happens to most people who install the atmosphere venting bov's. After a while you will learn how to adjust your driving so it doesn't stall. All i do is blip the throtle when coming to a stop ect. Do a search on the forum about this, been covered alot of times, you may find some use full tips.
Unfortunately blow off valves and skylines as some other member explained are not a good mix. I even use to have a GFB stealth that you get to adjust how much air is vented and how much is kept and car still didnt feel the same and idle was terrible. I know its not what you want to hear but if you want to have a car that runs well then install your stock bov.
i still have my stock plumback on my s1, no problems as in running, sometimes when letting clutch out a little to move forward in places like drive through with a little bit of throttle then go to put brakr on and clutch in cars idle does drop to close to a stall but then picks up again, only problem i have in regards to stalling hope this helps
Stalling when having a atmo bov installed is a really common thing. The reason it happens is because the afm detects the air going into the engine and puts more fuel in to burn the air, but the air is not getting into the combustion chamber, it's going out of the bov. I hope that made some sense.
As far as I know, it's something you just have to deal with if you're got a bov installed.
some people here adjust the idle just a little higher than stock, others just learn how to drive them like when you're about to stop change gear or clutch in when the idle is near idle speed. Or you rev it a little before you stop.
The main issue with atmospheric BOV's is the AFM... Once air has gone past that it is accounted for by the computer, any difference an atmospheric BOV will cause means there is air accounted for, but not being used. With MAP sensor its a different story as it reads manifold pressures not airflow before the turbo. With the plumb back system the air goes back through the turbo or the afm keeping it all in the circuit of the airflow so the ecu can adjust according to the afm readings. Some cars just handle it better than others, my mates 32 used to be perfectly fine with big turbosmart BOV's but my mates 33 would stall all the time with a Blitz one and then the HKS one.
Liam
Edited by FordyR31
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
