My car is now home and ready to be stripped... Pretty much all parts available...
Rear end damage...
Please call 0403 954 613 for more info
Thanks, Paul
hey mate
just spoke to you before.
i`m after the stereo bracket, stereo pocket that fills the gap below the stereo deck and the trim cover thing that sits around your stering coloum.
can be contacted on 0401 41 604
cheers simon.
is your gear stick boot in good conditon?, i wouldent mind that?.. do you have a 3inch separate turbo front pipe?. with no dump.. and how much for the engine strut brace??.
Appologies to those whom i haven't Pm'd back yet...
At the moment i'm trying to sell the car as it is as it's still drivable and repairable$$$$$$$$$$$$$$$$$
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
