so i just bought a R32 GTR V-SPEC 1 , ive just had a RZ supra so im not technicly minded about the RB26dett so im asking any one with a R32 GTR to tell me what time they hit boost as i was told mine spools a bit late so im hoping its got N1's in it lol just any facts about the engine would be greatfulyl apeciated ,
my GTR currently has a bigger fuel pump chipped ECU apexi SAFC BIGGER front mount than the stock one a quick shift on the 5speed and a exhaust any one know what sort of power i can expect ?
thanx , pism
Edited by pism
https://www.sau.com.au/forums/topic/178425-my-gtr/
Boost should, and I use that term loosely, come in @ around 3800RPM.
I would say that you would have more power than say a Diahutsu Charade...
270RWHP maybe not sure, GTR's are a black bag when it comes to power in stockish form......
All I can say is Dyno time!
Mike
Edited by MIKE_R32_GTR
https://www.sau.com.au/forums/topic/178425-my-gtr/#findComment-3255933
thanx man , yea i rekon about 300 i gotta get it dynoed i had all my work done at speedworks on my rz but they f*ked me around abit so im thinking xspeed would be my next choice but im not sure on prices any rough idea what i would cost to tune .
https://www.sau.com.au/forums/topic/178425-my-gtr/#findComment-3256260
u saystockish form the only thing that hasnt bin changed is the turbs and im 30% sure its got n1's lol cos it spools a bit l8a so im hoping for 350 maybe a lil more , am i dreaming ? please GOD OF SPEED LET IT BE LET ME MAKE DECENT POWER lol :D
https://www.sau.com.au/forums/topic/178425-my-gtr/#findComment-3256261
My stock non N1's kick full boost around 2500, So yours should spool on full boost around 3500 and I would say you figure for your power should be around the 350+ I would say with a tune it should get near the 400 mark. Thats what Ive been told. Have a look at the exhaust if you have the stock still you can save spool time by increaing the front pipes size.
https://www.sau.com.au/forums/topic/178425-my-gtr/#findComment-3256391
mine pumped 337hp on a apa hub dyno back in late 2004 @ speedworks osy park. Stock dumps with hte rest of the xhaust changed. Stock turbos @ 14psi with blitz pods. Ran a 179km/hr terminal speed @ the plex. Runs a crappy turbosmart bleed valve. Full boost ~3800-3900rpm
https://www.sau.com.au/forums/topic/178425-my-gtr/#findComment-3257129
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
