hi.
just wanting to see how much i can get for my rb25de motor. its still in the car awaiting removal. basically it can come with everything anyone would need, computer/loom, etc. but obviously depending on price. tis a strong motor. ... so what are people offering... out of a r33 btw. in brisbane. can ship anywhere in the world at buyers expense.
https://www.sau.com.au/forums/topic/178436-eoi-rb25de/
it clearly says brisbane. sorry won't seperate cams, have some rb20 cams but, they are apparently the same. non turbo 25 cams are no bigger than turbo ones. nrb20, $350, n its yours, for engine, with both manifolds.
Sorry champ I didn't read it well enough :thumbsup:
Any idea how much postage to Melbourne would cost?
I will give you $350, just depends how much postage is!
https://www.sau.com.au/forums/topic/178436-eoi-rb25de/#findComment-3259284
just got told these engines are worth alot more. just the heads are going for over 500. best offer over 350 by friday gets it. i dont' care if it needs to get posted. i'll drive it to any depot in brisbane, but you, have to organise it from there. tah
Edited by sic200
https://www.sau.com.au/forums/topic/178436-eoi-rb25de/#findComment-3259300
  • 4 weeks later...
