  • Replies 135
If I had lots of spare cash I'd get the 848 in white. Hotness.
You talking about the Ducati 848, little bro to the 1098?? They look like a pretty decent setup from what i've read. Very similar to the 1098..
Here's mine by the way next to a mates GSXR750..
How did the 1098S go? There is one for sale on on bike sales, 3,000kms for $26,000... So tempted to buy it...
the 1098 is nice but no match with my K6 - 1098 claimed hp is about 20hp less than that of the gsxr.
its like comparing a ferrari to a gtr...look great but gtr will hose it in almost every aspect in terms of performance
Yeh, I've read that in a few magazines... a bit of a shame. They are bringing out a 1098R which is mean to have around 180hp if I remember correctly.
well the 1098s is 36k with 160hp - any late model jap bike is 15-20k with 180hp!
the r model will be about 50k with 180hp if its lucky, they are still heavire than the jap bike!
i.e. k6 = 160kg whereas the 1098 id 171kg & ducati is still more than 3 times that of a jap bike
well u cant look at it like that, a duke is a vtwin as u know, theyre torque is much higher than that of ne of our bikes factory, in saying that, rwhp figure is not a comparison, its how fast the bike laps the track or the 0-100 100-200 0- 400m and so on, a duke is a throw around bike where most 4cylinder bikes lean for u... it all comes down to personnal prefferance and how well u can ride the bike, for example, Bayliss = Ducati Stoner = Ducati both worked bikes yes but stock or not they are proven to be much more quicker down the str8 than ne other jap bike. id like to see Rossi on a duke tbh
yes well the ducati is dominating the moto gp for the 1st time ever - good to see something different.
if its got 2 wheels i luv it
I think I'm going to upgrade to a CBR600RR or a R6
Use the Babyblade for the trackdays..
When you realise how slow and crap the CBR250 is compared to the CBR600/R6s etc, I doubt you'll want to use it on the track......
Got on a cbr600rr today $15,000 for a 07 model omg *drools* I want one! The R6's seem funny the cbr is a lot nicer.. Nearly fixed my cbr up to good standards.. Few more time, parts and tlc.
The 600 weighs the same as my 250. more sexy too!
so jealsous right now
Man my regulator rectifier has crapped out on me :banana: so upset.. I want to go for a ride but the battery is on charge too!
other then that everything else is fixed :blush:
I'm telling you now!!!! CBR600RR FTW!!!! Stuff the R6..
You're just jealous..
650 bah, need at least 1200 to have fun... j/k. I could probably be happy with the right 600 but right now the 1200 is too much fun.
How does everyone feel about the 19th or 20th of Jan for our SAU bike cruise?
That sounds ok pending that my bike is working.. and If I'm still in NSW
Anyone wanna sell me a VTR 1000 Regulator rectifier?
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
