Hi All,
I am looking at putting a td-06 25G high mount with external wastegate on my 34 soon and am wondering whether i should gone down a different path or not.
The mods on my car so far are:
Blitz twin plate clutch
Blitz front mount
Walbro Fuel pump
Pod filter
AVCR boost controller
PFC (not installed yet)
550 cc injectors (not installed yet)
Future mods before turbo:
260 degree Cams
Cam gear
oil cooler and remote oil filter
Looking for 250 - 300 rwkw.
Just want to see peoples opinions.
https://www.sau.com.au/forums/topic/178807-td-06-25g-on-r34gtt/
Looking for response more than out right power as i am not planning on doing a rebuild in the near future.
Otherwise i would be going down the path of a t04z and chasing over 400 rwkw, but i want to use this as a street car and the occasional track and drag day at this point.
Thanks MADGT4 for your response as there is one in the for sale section i am looking at purchasing but didnt know whether it was a good idea or not.
That is the purpose of this thread :glare:
What size housing is the turbo your looking at?
But i cant speak from experience though only from what i hear/read so i would possibly try and find someone that has a similar setup or better knowledge of the turbo.
At the end of the day from what i know though it is an ideal turbo for the 25!
td06-25g probably isnt the most responsive of the turbo range but makes up for it in power delivery i guess, try a gt30 or a 3037s for more response. I am a BIG fan of the td06-25g's so i would still say go for it, be a tough car then :D
depending on the housing size it will easily match a GT30 for response, in fact a T67 8cm (very similar) we did recently shat all over the GT30 the differrence in response was like 40rwkw between 3000-4500
260 degree Cams
Cam gear
if you are just looking at <300rwkw with top mount td0625g you will need none of the above, although oil cooler would be a good idea for track use.
you could easily get 280-290rwkw from what you have already but dont forget z32 afm.
cheers
yeah ex housing choice will change rpm response alot, a mate of mine had the smaller td06-20g on his r33 gtst not sure of ex housing size but it didnt hit hard till between 4500-5000. nice once it was on though..
It is said to be the 8cm version of the td-06 25g, so should hopefully be not too laggy.
I have two mates in Adelaide who have been driving around with 300rwkw for 4 years and have not had a problem and they drive there car everyday as well as doing a couple of track days.
I think it is more about the tune and support mods as well as the way you drive the car to how long your engine will last.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
