Can anyone help me!!
I've got a GTR32 and having problems with the harmonic balancer, I've gotten it tighten twice, but it keeps getting loose after a few days. It's been tighten by hand using a wrench. Is there a special tool needed to tighten it?
Has anyone had this problem before, and how do I fix it??
Chris
Hi Chris, I have found the best way to undo and tighten the harmonic balancer is to remove one of the clutch slave cylinder bolts (the one below the flywheel ring gear) Find a longer bolt with the same thread and grind a taper (point) on the end.
(so the thread does not get damaged when the bolt is removed) And then wind the bolt in (tight) so it contacts and locks the fly wheel. You will find you can put a lot of tension on the HB bolt with this tip. Good luck. Clive
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
