HKS,- turbos T-28s, air pods, intercooler 100mm thick, blow off valves, 4 dash gauges & exhaust, all HKS, Blitz turbo timer & boost control. Full nismo dash, nismo suspension bigger injectors(dont know what size) nismo twin plate clutch & r34 factory GTR rims. DATS all that i know , might be more, just bought it a month ago . DOnt know much about turbo cars
https://www.sau.com.au/forums/topic/17911-internals/#findComment-373307
A compression test would not help you.
A compression test helps when you want to get an idea of how worn an engine is, in terms of individual cylinders,
ie. the pistons in the cylinders with poor compression would have worn piston rings. This could be the cause of exessive oil usage etc...
So you could do a compression test on your engine(i did before i bought my car for peace of mind), but all it would tell you is how worn parts of the engine are, no matter if they are original or aftermarket.
https://www.sau.com.au/forums/topic/17911-internals/#findComment-373424
Grab an endoscope, remove the spark plugs and look into the bore, you may be able to tell by the (domed/machined perhaps) pistons that the pistons arent stock.
Reome rocker covers to see about cams is pretty easy.
Thats about the best i can offer other then bouncing it of 10,000rpm a few times and seeing if she holds together:D
May be able to get the endoscope thru the oil pan hole and see the bottom end???
https://www.sau.com.au/forums/topic/17911-internals/#findComment-373769
Aftermarket pistons could give a different reading to stock, but the ones in your car might just be to the same specs as the stock ones.
JimX :
What is piston slap? My knowledge doesnt extend that far lol
I have Wiseco forged pistons in my car (everything else is stock i feel dumb for not upgrading it to take advantage of this...) and the engine feels just like any other when cold or warm...
https://www.sau.com.au/forums/topic/17911-internals/#findComment-374496
Piston slap is when the pistons rattle around in the cylinders due to being a tad too small. There was another thread here somewhere where someone was talking of their forgies being "noisy" when cold because they expand more with heat, or something.
If you have Wiseco forged pistons and it's completely normal when cold then they're the kind that I think I'll be after at rebuild time :P
https://www.sau.com.au/forums/topic/17911-internals/#findComment-374523
The standad cast pistons have different tollerances than forgies.
An enginebuilder should get the bores matched to the pistons used in that bore only, to get a better, overall balanaced engine.
Some aftermarket forgies expand at different rates due to the different material, and piston could be a few thou smaller than the bore which will cause the slap to occure when the engine is cold. As the piston warms up (5-10 mins to get eveything warm) then the tollerances are better and more to what you would expect.
You will blow your motor if you were to give it a trash when cold running forgies. Maybe not in an instant, but do that every time you drive your car (even comming on 6psi + boost) then its a road to trouble. In warming up your engine, your warming up the fluids which are at different viscosities when warm and your giving everything a chance to expand to the right tollerance. Iron expands differently to ally, the powered steel conrods expand differently to the steel block and metal bearings etc.
Some car manufactures run forgies standard in daily driver cars, but they have invested millions in fabrication and have designed the engines to incorporate with the ups and downs of forgies.
Using an endoscope might yield some results, particularly detonation signs, burn characteristics and other things that might be of interest.
https://www.sau.com.au/forums/topic/17911-internals/#findComment-374656
Ah ok so 'piston slap' is pretty self explanatory, i figured that is what is was... thanx for the explanation.
to JimX:
I have never heard any rattles from the engine when cold, it idles perfectly smoothly just as you would expect it to. I have also never heard it while driving when the engine is cold....
But then again, i dont think i have ever driven the car without letting it warm for several mintues, or keeping the revs way below 2 grand till warm :)
So i guess in my case the engine builder matched the tolerances, while in the person in the other thread who was complaining of slap did not have a mechanic who cared as much..
https://www.sau.com.au/forums/topic/17911-internals/#findComment-375461
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
