With all the recent rain & storms, I have heard on the radio about & seen driving around, quite a few potholes on some main roads. Anyone with half a brain would know hitting one of these at 80kph or so there is a chance isn't going to end pretty with tyres, maybe rims, possible body damage and in worst case control of the vehicle, so keep an eye out for them out there :(
Even some that have been previously filled in have become unsettled so will have a similar effect. Posting this because I've seen some on a road I've driven on pretty much every day for the last 3-4 years & there hasn't been anything but the other day I spotted some so just something to think about :(
https://www.sau.com.au/forums/topic/179135-road-conditions/
Yeah I've noticed this too, the left hand lane heading east on Guildford Rd in Maylands is pretty sketchy and there's not really any room to avoid them in traffic.
Edit: btw [Michael] the number plate lights in your rear weren't working the other night..
Edited by bubba
https://www.sau.com.au/forums/topic/179135-road-conditions/#findComment-3265179
thanks for that bubba better go change them :(
https://www.sau.com.au/forums/topic/179135-road-conditions/#findComment-3265185
There is a nice big rim killer pothole on Gnangara road near Beechboro road.
Also, my mate damaged his tyre and NEW rim at the corner of Hutton and Guthrie in Osb PArk. Think councils need to pull their finger out!
https://www.sau.com.au/forums/topic/179135-road-conditions/#findComment-3265245
When i was in perth yesterday i saw armadale road had pot holes everywhere. Heaps near midland brick also armadale rd and nicholson (its just starting to get there) and also just past lake rd when your heading towards armadale.
The council definetly needs to stop using the shovels as a leaning device and use them to fill the holes up
https://www.sau.com.au/forums/topic/179135-road-conditions/#findComment-3266050
yeh roads all over the place have just got a whole lot worse. Some big pot holes near my house haven't been fixed for years.....it's bulls#&t. The council needs to get there act together and fix them all. To make it worse, when i try to avoid them by swerving (only when theres no traffic around) i'am yelled at by padestrians cause they think i'm a hoon....it sucks.
https://www.sau.com.au/forums/topic/179135-road-conditions/#findComment-3266122
That's when you need to do a handbrake turn, smash 2nd up to them & politely explain you were simply manouvering your automobile around the eroded surface of the street in a controlled manner. :(
https://www.sau.com.au/forums/topic/179135-road-conditions/#findComment-3266635
If I hit boost anywhere I get yelled at and called a hoon! I had some old guy run out of his house brandishing his fist shouting "IF YOU SPEED THROUGH HERE AGAIN I'LL THROW A F*@KING BRICK THROUGH YOUR WINDSCREEN!" I wasn't speeding, my car is just loud and sounds like it's going fast when it's not.. I came to a complete stop half way through the intersection, flipped him off and was about to drop a big smokey burnout but decided against it incase it stepped right out and knocked the old lady off her bicycle that was riding on the road next to me.
https://www.sau.com.au/forums/topic/179135-road-conditions/#findComment-3266652
The ones I noticed the most were a few on West Coast Hwy & the left hand filter lane turning onto Wanneroo Rd from Ocean Reef Rd....with that being a few minutes from home I've turned there just about every day for the last 3 years & there hasn't been anything, so hitting all 3 isn't good!
https://www.sau.com.au/forums/topic/179135-road-conditions/#findComment-3267942
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
