I ant got no cold nor am i getting one... I drink to much for any virus to survive in my body...
But just to be sure I better ban you for a week so you stop posting as it might be contagious through the forum...
lol......do you find a bit of JD on your cornflakes works too? :nyaanyaa:
this is easily the worst flu ive ever seen
i never ever get sick
and i had it for just under two months
sortest throat, fever and the lung butter
im still coughing up solid bits of it months later after exercise
dont think alcohol stops this flu
lung butter.. haha nice description..
you've got myalgia which is just part of the deal with viral illnesses.. general muscle soreness your shoulders and hips will probably hurt also but don't worry its just muscle pain that will go when the infection clears
again, if you're taking paracetamol for your fevers, this has the dual action of helping the muscle pain :down:
ive got flu aswell, but i felt it coming on thursday arvo and went home from work after lunch, then just hooked into some cold and flu tablets then went to bed, felt so much better friday and today am staying the same as yesterday. but its more gone away from fever type stuff now into annoying head cold status.
Edited by 85URK
again, if you're taking paracetamol for your fevers, this has the dual action of helping the muscle pain :)
no panadol or heron for me. :) my ex took a panadol everytime she felt sick and look at her now her imune system is as effective as a stripper for a blind guy..
thanks warren been a great help. :)
might stock some of that stuff up next time around
panadol (paracetamol) has no effect on the immune system.. that's just a myth
but hey its up to you, you can take soil mixed with lavendar leaves and pray over it facing north if that will float your boat.
all i know is the evidence says paracetamol works and it is a very benign drug in low doses..
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
