yeh the one im talking about was the grey R32, 13.72 was the time beer baron, dont think it was on slicks when it did it and had a strange miss-fire halfway through second.
and i think slicks would make a differnce as to how quick you reach a certain speed, 0-300 is a timed event, slicks = less time wheel spinning, and more time on the power, means you get to that speed in less time. unless you want to get into maths/physics with rolling resistance at higher speed etc, i really cant see how it wouldnt make a difference
i know you like your drag racing, go run on a set of $30 retreads vs some real good tyres. 0-300 is basically the same format as drag racing, just with a different goal
I'm not getting into an argument over a record that's not even mine. I only posted it as a matter of interest.
I have the official times in an old HPI magazine, ill try find it.. ALso, I too agree that their is an advatage to Slicks vs. Steet Legal tyres. Was this new one running an Engine Under 3.0ltrs?
Edited by Gazzilla
  • 2 months later...
Hi Everyone
I just got sent this link and i thought i would post to clear a few things up.
The run was done on a set of Radial tyres,the same type tyre as the Nitto.
If anyone wants to have a go at this record,it cant be done on a prepped drag strip.
you also need to have propper timing gear fitted.
Keith
Hi Everyone
Keith
Congrats on the record mate, thats a seriously impressive time!!
Don't suppose you could give us some info on the engine setup?
Cheers
Cheers
Hi PM-R33
Here is the spec of the engine.
3L OS Giken motor, uprated Tomei oil pump, RB Motorsport big sump and Trust remote oil filter kit, RB Motorsport modified
oil feed to cylinder head, Mocal oil cooler,RB Motorsport cylinder head Oil Scavenge Pump system,Turbo Dynamics 1250 bhp GT spec single turbo,Trust 60mm racing wastegate and short dump pipe, Trust RSPL-R 170mm-thick cored
intercooler, RB Motorsport custom hard pipe kit, Trust racing dump valve,R.B Motorsport 110mm throttle body, R.B Motorsport ultra-large plenum, HKS 300+ degree Step 3 PRO L camshafts, OS Giken 3L adjustable cam pulleys,Tomei kevlar-reinforced timing belt, Tomei valve springs and retainers, RB Motorsport-spec modified cylinder head with 1.5mm Oversize IN /EX valves,
Trust 1.2mm head gasket, RB Motorsport fuel rail, 1600cc injectors, New Bosch 044 external fuel pump system,uprated fuel pressure regulator,12-litre alloy fuel cell, Trust OS 3L exhaust manifold, Meercat modified 5" exhaust system, Trust uprated radiator,
RB Motorsport modified cylinder head cooling system, Autronic SM4 engine management unit, Autronic 500R High power Direct Fire ignition CDI unit 605 Volts, large Autronic boost solenoid, six Bosch single-plug coils Power Output expect 1200 true bhp.
We also run the car at 9000 revs with 3 bar boost.
Edited by Team Cowie
thanks guys,I hope to have the incar vid soon
here is the data from the run
Below is the data pasted directly from the Datron file:
It shows:
Distance line every 1/4 mile (1320ft) and additionally at 60ft.
It also shows a Time line every 10mph and additionally at 100kmh (62.1mph).
0-30 mph - 1.226
0-60 mph - 2.539
0-100 mph - 4.346
0-150 mph - 8.085
0-200 mph - 14.751
0-187.31 12.474sec
300kmh is 186.4mph (exact times details of this to follow)
60ft 1.828, 46.03
1/4mile 9.364, 163.73
1/2mile 14.333, 197.78
Time File, C:\Data\playtime\Cowie-009T.csv
Report File, C:\Data\playtime\Cowie-009R.csv
Top Speed, 206.4 mph
Min Satellites, 9
Time(s), Speed( mph), Distance(ft), GPSTime, GPSDate, #sats
0.000, 0.00, 0.00, 14:18:19.002, 29/07/2007, 9
0.421, 10.00, 3.10, 14:18:19.422, 29/07/2007, 9
0.838, 20.00, 12.34, 14:18:19.840, 29/07/2007, 9
1.226, 30.00, 26.50, 14:18:20.228, 29/07/2007, 9
1.606, 40.00, 45.96, 14:18:20.608, 29/07/2007, 9
1.828, 46.03, 60.00, 14:18:20.830, 29/07/2007, 9
1.978, 50.00, 70.59, 14:18:20.979, 29/07/2007, 9
2.539, 60.00, 114.99, 14:18:21.541, 29/07/2007, 9
2.611, 62.14, 121.22, 14:18:21.613, 29/07/2007, 9
2.883, 70.00, 147.76, 14:18:21.885, 29/07/2007, 9
3.260, 80.00, 189.30, 14:18:22.262, 29/07/2007, 9
3.906, 90.00, 269.15, 14:18:22.907, 29/07/2007, 9
4.346, 100.00, 330.53, 14:18:23.348, 29/07/2007, 9
5.001, 110.00, 432.30, 14:18:24.003, 29/07/2007, 9
5.696, 120.00, 548.67, 14:18:24.698, 29/07/2007, 9
6.298, 130.00, 659.03, 14:18:25.300, 29/07/2007, 9
7.341, 140.00, 866.28, 14:18:26.343, 29/07/2007, 9
8.085, 150.00, 1024.58, 14:18:27.087, 29/07/2007, 9
8.924, 160.00, 1215.43, 14:18:27.925, 29/07/2007, 9
9.364, 163.73, 1320.00, 14:18:28.366, 29/07/2007, 9
10.377, 170.00, 1566.42, 14:18:29.379, 29/07/2007, 9
11.597, 180.00, 1879.83, 14:18:30.599, 29/07/2007, 9
13.010, 190.00, 2263.43, 14:18:32.011, 29/07/2007, 9
14.333, 197.78, 2640.00, 14:18:33.334, 29/07/2007, 9
14.751, 200.00, 2762.09, 14:18:33.753, 29/07/2007, 9
17.126, 200.00, 3470.83, 14:18:36.127, 29/07/2007, 9
17.818, 190.00, 3668.89, 14:18:36.820, 29/07/2007, 9
18.567, 180.00, 3872.14, 14:18:37.569, 29/07/2007, 9
18.904, 175.68, 3960.00, 14:18:37.906, 29/07/2007, 9
19.311, 170.00, 4063.22, 14:18:38.313, 29/07/2007, 9
20.009, 160.00, 4232.19, 14:18:39.011, 29/07/2007, 9
20.852, 150.00, 4423.65, 14:18:39.853, 29/07/2007, 9
21.696, 140.00, 4602.68, 14:18:40.698, 29/07/2007, 9
22.787, 130.00, 4819.60, 14:18:41.789, 29/07/2007, 9
0.015, 0.48, 0.01, 14:18:19.017, 29/07/2007, 9
0.215, 5.04, 0.82, 14:18:19.217, 29/07/2007, 9
0.415, 9.87, 3.00, 14:18:19.417, 29/07/2007, 9
0.615, 14.68, 6.60, 14:18:19.617, 29/07/2007, 9
0.815, 19.43, 11.61, 14:18:19.817, 29/07/2007, 9
1.015, 24.41, 18.04, 14:18:20.017, 29/07/2007, 9
1.215, 29.71, 25.97, 14:18:20.217, 29/07/2007, 9
1.415, 34.89, 35.45, 14:18:20.417, 29/07/2007, 9
1.615, 40.24, 46.47, 14:18:20.617, 29/07/2007, 9
1.815, 45.68, 59.07, 14:18:20.817, 29/07/2007, 9
2.015, 51.00, 73.25, 14:18:21.017, 29/07/2007, 9
2.215, 51.86, 88.33, 14:18:21.217, 29/07/2007, 9
2.415, 56.30, 104.20, 14:18:21.417, 29/07/2007, 9
2.615, 62.26, 121.58, 14:18:21.617, 29/07/2007, 9
2.815, 68.05, 140.70, 14:18:21.817, 29/07/2007, 9
3.015, 73.80, 161.50, 14:18:22.017, 29/07/2007, 9
3.215, 79.11, 183.92, 14:18:22.217, 29/07/2007, 9
3.415, 83.06, 207.71, 14:18:22.417, 29/07/2007, 9
3.615, 83.13, 232.08, 14:18:22.617, 29/07/2007, 9
3.815, 87.88, 257.16, 14:18:22.817, 29/07/2007, 9
4.015, 92.56, 283.63, 14:18:23.017, 29/07/2007, 9
4.215, 97.07, 311.44, 14:18:23.217, 29/07/2007, 9
4.415, 101.54, 340.57, 14:18:23.417, 29/07/2007, 9
4.615, 105.64, 370.95, 14:18:23.617, 29/07/2007, 9
4.815, 109.00, 402.43, 14:18:23.817, 29/07/2007, 9
5.015, 110.08, 434.57, 14:18:24.017, 29/07/2007, 9
5.215, 111.12, 467.01, 14:18:24.217, 29/07/2007, 9
5.415, 114.86, 500.15, 14:18:24.417, 29/07/2007, 9
5.615, 118.56, 534.38, 14:18:24.617, 29/07/2007, 9
5.815, 122.11, 569.68, 14:18:24.817, 29/07/2007, 9
6.015, 125.35, 605.97, 14:18:25.017, 29/07/2007, 9
6.215, 128.67, 643.23, 14:18:25.217, 29/07/2007, 9
6.415, 131.89, 681.44, 14:18:25.417, 29/07/2007, 9
6.615, 134.51, 720.51, 14:18:25.617, 29/07/2007, 9
6.815, 136.41, 760.25, 14:18:25.817, 29/07/2007, 9
7.015, 136.20, 800.23, 14:18:26.017, 29/07/2007, 9
7.215, 138.25, 840.48, 14:18:26.217, 29/07/2007, 9
7.415, 141.03, 881.44, 14:18:26.417, 29/07/2007, 9
7.615, 143.85, 923.22, 14:18:26.617, 29/07/2007, 9
7.815, 146.54, 965.81, 14:18:26.817, 29/07/2007, 9
8.015, 149.11, 1009.17, 14:18:27.017, 29/07/2007, 9
8.215, 151.66, 1053.28, 14:18:27.217, 29/07/2007, 9
8.415, 154.14, 1098.13, 14:18:27.417, 29/07/2007, 9
8.615, 156.60, 1143.71, 14:18:27.617, 29/07/2007, 9
8.815, 158.85, 1189.97, 14:18:27.817, 29/07/2007, 9
9.015, 160.97, 1236.88, 14:18:28.017, 29/07/2007, 9
9.215, 162.75, 1284.36, 14:18:28.217, 29/07/2007, 9
9.415, 164.07, 1332.29, 14:18:28.417, 29/07/2007, 9
9.615, 163.28, 1380.30, 14:18:28.617, 29/07/2007, 9
9.815, 164.80, 1428.41, 14:18:28.817, 29/07/2007, 9
10.015, 166.61, 1477.02, 14:18:29.017, 29/07/2007, 9
10.215, 168.51, 1526.17, 14:18:29.217, 29/07/2007, 9
10.415, 170.35, 1575.87, 14:18:29.417, 29/07/2007, 9
10.615, 172.09, 1626.09, 14:18:29.617, 29/07/2007, 9
10.815, 173.74, 1676.81, 14:18:29.817, 29/07/2007, 9
11.015, 175.54, 1728.04, 14:18:30.017, 29/07/2007, 9
11.215, 177.07, 1779.75, 14:18:30.217, 29/07/2007, 9
11.415, 178.63, 1831.92, 14:18:30.417, 29/07/2007, 9
11.615, 180.13, 1884.54, 14:18:30.617, 29/07/2007, 9
11.815, 181.65, 1937.60, 14:18:30.817, 29/07/2007, 9
12.015, 183.16, 1991.10, 14:18:31.017, 29/07/2007, 9
12.215, 184.73, 2045.06, 14:18:31.217, 29/07/2007, 9
12.415, 186.02, 2099.43, 14:18:31.417, 29/07/2007, 9
12.615, 187.31, 2154.19, 14:18:31.617, 29/07/2007, 9
12.815, 188.83, 2209.35, 14:18:31.817, 29/07/2007, 9
13.015, 190.03, 2264.92, 14:18:32.017, 29/07/2007, 9
13.215, 191.36, 2320.85, 14:18:32.217, 29/07/2007, 9
13.415, 192.70, 2377.18, 14:18:32.417, 29/07/2007, 9
13.615, 193.76, 2433.86, 14:18:32.617, 29/07/2007, 9
13.815, 195.00, 2490.88, 14:18:32.817, 29/07/2007, 9
14.015, 196.16, 2548.25, 14:18:33.017, 29/07/2007, 9
14.215, 197.16, 2605.93, 14:18:33.217, 29/07/2007, 9
14.415, 198.22, 2663.92, 14:18:33.417, 29/07/2007, 9
14.615, 199.37, 2722.23, 14:18:33.617, 29/07/2007, 9
14.815, 200.30, 2780.85, 14:18:33.817, 29/07/2007, 9
15.015, 201.16, 2839.72, 14:18:34.017, 29/07/2007, 9
15.215, 202.03, 2898.86, 14:18:34.217, 29/07/2007, 9
15.415, 202.83, 2958.23, 14:18:34.417, 29/07/2007, 9
15.615, 203.41, 3017.81, 14:18:34.617, 29/07/2007, 9
15.815, 204.49, 3077.64, 14:18:34.817, 29/07/2007, 9
16.015, 205.01, 3137.70, 14:18:35.017, 29/07/2007, 9
16.215, 205.82, 3197.95, 14:18:35.217, 29/07/2007, 9
16.415, 206.41, 3258.41, 14:18:35.417, 29/07/2007, 9
16.615, 206.04, 3318.90, 14:18:35.617, 29/07/2007, 9
16.815, 203.72, 3378.99, 14:18:35.817, 29/07/2007, 9
17.015, 201.45, 3438.42, 14:18:36.017, 29/07/2007, 9
17.215, 198.83, 3497.12, 14:18:36.217, 29/07/2007, 9
17.415, 195.67, 3554.98, 14:18:36.417, 29/07/2007, 9
17.615, 192.64, 3611.93, 14:18:36.617, 29/07/2007, 9
17.815, 190.04, 3668.05, 14:18:36.817, 29/07/2007, 9
18.015, 187.43, 3723.42, 14:18:37.017, 29/07/2007, 9
18.215, 184.73, 3778.00, 14:18:37.217, 29/07/2007, 9
18.415, 182.18, 3831.81, 14:18:37.417, 29/07/2007, 9
18.615, 179.31, 3884.83, 14:18:37.617, 29/07/2007, 9
18.815, 176.81, 3937.06, 14:18:37.817, 29/07/2007, 9
19.015, 174.28, 3988.55, 14:18:38.017, 29/07/2007, 9
19.215, 171.45, 4039.25, 14:18:38.217, 29/07/2007, 9
19.415, 168.43, 4089.10, 14:18:38.417, 29/07/2007, 9
19.615, 165.58, 4138.09, 14:18:38.617, 29/07/2007, 9
19.815, 162.61, 4186.22, 14:18:38.817, 29/07/2007, 9
20.015, 159.92, 4233.52, 14:18:39.017, 29/07/2007, 9
20.215, 157.53, 4280.08, 14:18:39.217, 29/07/2007, 9
20.415, 155.24, 4325.95, 14:18:39.417, 29/07/2007, 9
20.615, 152.97, 4371.16, 14:18:39.617, 29/07/2007, 9
In addition to the spread sheets which are generated, there is also a raw data file which I have used to create the graph below:
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
