yeh the one im talking about was the grey R32, 13.72 was the time beer baron, dont think it was on slicks when it did it and had a strange miss-fire halfway through second.
and i think slicks would make a differnce as to how quick you reach a certain speed, 0-300 is a timed event, slicks = less time wheel spinning, and more time on the power, means you get to that speed in less time. unless you want to get into maths/physics with rolling resistance at higher speed etc, i really cant see how it wouldnt make a difference
i know you like your drag racing, go run on a set of $30 retreads vs some real good tyres. 0-300 is basically the same format as drag racing, just with a different goal
I'm not getting into an argument over a record that's not even mine. I only posted it as a matter of interest.
I have the official times in an old HPI magazine, ill try find it.. ALso, I too agree that their is an advatage to Slicks vs. Steet Legal tyres. Was this new one running an Engine Under 3.0ltrs?
Edited by Gazzilla
  • 2 months later...
Hi Everyone
I just got sent this link and i thought i would post to clear a few things up.
The run was done on a set of Radial tyres,the same type tyre as the Nitto.
If anyone wants to have a go at this record,it cant be done on a prepped drag strip.
you also need to have propper timing gear fitted.
Keith
Hi Everyone
Keith
Congrats on the record mate, thats a seriously impressive time!!
Don't suppose you could give us some info on the engine setup?
Cheers
Cheers
Hi PM-R33
Here is the spec of the engine.
3L OS Giken motor, uprated Tomei oil pump, RB Motorsport big sump and Trust remote oil filter kit, RB Motorsport modified
oil feed to cylinder head, Mocal oil cooler,RB Motorsport cylinder head Oil Scavenge Pump system,Turbo Dynamics 1250 bhp GT spec single turbo,Trust 60mm racing wastegate and short dump pipe, Trust RSPL-R 170mm-thick cored
intercooler, RB Motorsport custom hard pipe kit, Trust racing dump valve,R.B Motorsport 110mm throttle body, R.B Motorsport ultra-large plenum, HKS 300+ degree Step 3 PRO L camshafts, OS Giken 3L adjustable cam pulleys,Tomei kevlar-reinforced timing belt, Tomei valve springs and retainers, RB Motorsport-spec modified cylinder head with 1.5mm Oversize IN /EX valves,
Trust 1.2mm head gasket, RB Motorsport fuel rail, 1600cc injectors, New Bosch 044 external fuel pump system,uprated fuel pressure regulator,12-litre alloy fuel cell, Trust OS 3L exhaust manifold, Meercat modified 5" exhaust system, Trust uprated radiator,
RB Motorsport modified cylinder head cooling system, Autronic SM4 engine management unit, Autronic 500R High power Direct Fire ignition CDI unit 605 Volts, large Autronic boost solenoid, six Bosch single-plug coils Power Output expect 1200 true bhp.
We also run the car at 9000 revs with 3 bar boost.
Edited by Team Cowie
thanks guys,I hope to have the incar vid soon
here is the data from the run
Below is the data pasted directly from the Datron file:
It shows:
Distance line every 1/4 mile (1320ft) and additionally at 60ft.
It also shows a Time line every 10mph and additionally at 100kmh (62.1mph).
0-30 mph - 1.226
0-60 mph - 2.539
0-100 mph - 4.346
0-150 mph - 8.085
0-200 mph - 14.751
0-187.31 12.474sec
300kmh is 186.4mph (exact times details of this to follow)
60ft 1.828, 46.03
1/4mile 9.364, 163.73
1/2mile 14.333, 197.78
Time File, C:\Data\playtime\Cowie-009T.csv
Report File, C:\Data\playtime\Cowie-009R.csv
Top Speed, 206.4 mph
Min Satellites, 9
Time(s), Speed( mph), Distance(ft), GPSTime, GPSDate, #sats
0.000, 0.00, 0.00, 14:18:19.002, 29/07/2007, 9
0.421, 10.00, 3.10, 14:18:19.422, 29/07/2007, 9
0.838, 20.00, 12.34, 14:18:19.840, 29/07/2007, 9
1.226, 30.00, 26.50, 14:18:20.228, 29/07/2007, 9
1.606, 40.00, 45.96, 14:18:20.608, 29/07/2007, 9
1.828, 46.03, 60.00, 14:18:20.830, 29/07/2007, 9
1.978, 50.00, 70.59, 14:18:20.979, 29/07/2007, 9
2.539, 60.00, 114.99, 14:18:21.541, 29/07/2007, 9
2.611, 62.14, 121.22, 14:18:21.613, 29/07/2007, 9
2.883, 70.00, 147.76, 14:18:21.885, 29/07/2007, 9
3.260, 80.00, 189.30, 14:18:22.262, 29/07/2007, 9
3.906, 90.00, 269.15, 14:18:22.907, 29/07/2007, 9
4.346, 100.00, 330.53, 14:18:23.348, 29/07/2007, 9
5.001, 110.00, 432.30, 14:18:24.003, 29/07/2007, 9
5.696, 120.00, 548.67, 14:18:24.698, 29/07/2007, 9
6.298, 130.00, 659.03, 14:18:25.300, 29/07/2007, 9
7.341, 140.00, 866.28, 14:18:26.343, 29/07/2007, 9
8.085, 150.00, 1024.58, 14:18:27.087, 29/07/2007, 9
8.924, 160.00, 1215.43, 14:18:27.925, 29/07/2007, 9
9.364, 163.73, 1320.00, 14:18:28.366, 29/07/2007, 9
10.377, 170.00, 1566.42, 14:18:29.379, 29/07/2007, 9
11.597, 180.00, 1879.83, 14:18:30.599, 29/07/2007, 9
13.010, 190.00, 2263.43, 14:18:32.011, 29/07/2007, 9
14.333, 197.78, 2640.00, 14:18:33.334, 29/07/2007, 9
14.751, 200.00, 2762.09, 14:18:33.753, 29/07/2007, 9
17.126, 200.00, 3470.83, 14:18:36.127, 29/07/2007, 9
17.818, 190.00, 3668.89, 14:18:36.820, 29/07/2007, 9
18.567, 180.00, 3872.14, 14:18:37.569, 29/07/2007, 9
18.904, 175.68, 3960.00, 14:18:37.906, 29/07/2007, 9
19.311, 170.00, 4063.22, 14:18:38.313, 29/07/2007, 9
20.009, 160.00, 4232.19, 14:18:39.011, 29/07/2007, 9
20.852, 150.00, 4423.65, 14:18:39.853, 29/07/2007, 9
21.696, 140.00, 4602.68, 14:18:40.698, 29/07/2007, 9
22.787, 130.00, 4819.60, 14:18:41.789, 29/07/2007, 9
0.015, 0.48, 0.01, 14:18:19.017, 29/07/2007, 9
0.215, 5.04, 0.82, 14:18:19.217, 29/07/2007, 9
0.415, 9.87, 3.00, 14:18:19.417, 29/07/2007, 9
0.615, 14.68, 6.60, 14:18:19.617, 29/07/2007, 9
0.815, 19.43, 11.61, 14:18:19.817, 29/07/2007, 9
1.015, 24.41, 18.04, 14:18:20.017, 29/07/2007, 9
1.215, 29.71, 25.97, 14:18:20.217, 29/07/2007, 9
1.415, 34.89, 35.45, 14:18:20.417, 29/07/2007, 9
1.615, 40.24, 46.47, 14:18:20.617, 29/07/2007, 9
1.815, 45.68, 59.07, 14:18:20.817, 29/07/2007, 9
2.015, 51.00, 73.25, 14:18:21.017, 29/07/2007, 9
2.215, 51.86, 88.33, 14:18:21.217, 29/07/2007, 9
2.415, 56.30, 104.20, 14:18:21.417, 29/07/2007, 9
2.615, 62.26, 121.58, 14:18:21.617, 29/07/2007, 9
2.815, 68.05, 140.70, 14:18:21.817, 29/07/2007, 9
3.015, 73.80, 161.50, 14:18:22.017, 29/07/2007, 9
3.215, 79.11, 183.92, 14:18:22.217, 29/07/2007, 9
3.415, 83.06, 207.71, 14:18:22.417, 29/07/2007, 9
3.615, 83.13, 232.08, 14:18:22.617, 29/07/2007, 9
3.815, 87.88, 257.16, 14:18:22.817, 29/07/2007, 9
4.015, 92.56, 283.63, 14:18:23.017, 29/07/2007, 9
4.215, 97.07, 311.44, 14:18:23.217, 29/07/2007, 9
4.415, 101.54, 340.57, 14:18:23.417, 29/07/2007, 9
4.615, 105.64, 370.95, 14:18:23.617, 29/07/2007, 9
4.815, 109.00, 402.43, 14:18:23.817, 29/07/2007, 9
5.015, 110.08, 434.57, 14:18:24.017, 29/07/2007, 9
5.215, 111.12, 467.01, 14:18:24.217, 29/07/2007, 9
5.415, 114.86, 500.15, 14:18:24.417, 29/07/2007, 9
5.615, 118.56, 534.38, 14:18:24.617, 29/07/2007, 9
5.815, 122.11, 569.68, 14:18:24.817, 29/07/2007, 9
6.015, 125.35, 605.97, 14:18:25.017, 29/07/2007, 9
6.215, 128.67, 643.23, 14:18:25.217, 29/07/2007, 9
6.415, 131.89, 681.44, 14:18:25.417, 29/07/2007, 9
6.615, 134.51, 720.51, 14:18:25.617, 29/07/2007, 9
6.815, 136.41, 760.25, 14:18:25.817, 29/07/2007, 9
7.015, 136.20, 800.23, 14:18:26.017, 29/07/2007, 9
7.215, 138.25, 840.48, 14:18:26.217, 29/07/2007, 9
7.415, 141.03, 881.44, 14:18:26.417, 29/07/2007, 9
7.615, 143.85, 923.22, 14:18:26.617, 29/07/2007, 9
7.815, 146.54, 965.81, 14:18:26.817, 29/07/2007, 9
8.015, 149.11, 1009.17, 14:18:27.017, 29/07/2007, 9
8.215, 151.66, 1053.28, 14:18:27.217, 29/07/2007, 9
8.415, 154.14, 1098.13, 14:18:27.417, 29/07/2007, 9
8.615, 156.60, 1143.71, 14:18:27.617, 29/07/2007, 9
8.815, 158.85, 1189.97, 14:18:27.817, 29/07/2007, 9
9.015, 160.97, 1236.88, 14:18:28.017, 29/07/2007, 9
9.215, 162.75, 1284.36, 14:18:28.217, 29/07/2007, 9
9.415, 164.07, 1332.29, 14:18:28.417, 29/07/2007, 9
9.615, 163.28, 1380.30, 14:18:28.617, 29/07/2007, 9
9.815, 164.80, 1428.41, 14:18:28.817, 29/07/2007, 9
10.015, 166.61, 1477.02, 14:18:29.017, 29/07/2007, 9
10.215, 168.51, 1526.17, 14:18:29.217, 29/07/2007, 9
10.415, 170.35, 1575.87, 14:18:29.417, 29/07/2007, 9
10.615, 172.09, 1626.09, 14:18:29.617, 29/07/2007, 9
10.815, 173.74, 1676.81, 14:18:29.817, 29/07/2007, 9
11.015, 175.54, 1728.04, 14:18:30.017, 29/07/2007, 9
11.215, 177.07, 1779.75, 14:18:30.217, 29/07/2007, 9
11.415, 178.63, 1831.92, 14:18:30.417, 29/07/2007, 9
11.615, 180.13, 1884.54, 14:18:30.617, 29/07/2007, 9
11.815, 181.65, 1937.60, 14:18:30.817, 29/07/2007, 9
12.015, 183.16, 1991.10, 14:18:31.017, 29/07/2007, 9
12.215, 184.73, 2045.06, 14:18:31.217, 29/07/2007, 9
12.415, 186.02, 2099.43, 14:18:31.417, 29/07/2007, 9
12.615, 187.31, 2154.19, 14:18:31.617, 29/07/2007, 9
12.815, 188.83, 2209.35, 14:18:31.817, 29/07/2007, 9
13.015, 190.03, 2264.92, 14:18:32.017, 29/07/2007, 9
13.215, 191.36, 2320.85, 14:18:32.217, 29/07/2007, 9
13.415, 192.70, 2377.18, 14:18:32.417, 29/07/2007, 9
13.615, 193.76, 2433.86, 14:18:32.617, 29/07/2007, 9
13.815, 195.00, 2490.88, 14:18:32.817, 29/07/2007, 9
14.015, 196.16, 2548.25, 14:18:33.017, 29/07/2007, 9
14.215, 197.16, 2605.93, 14:18:33.217, 29/07/2007, 9
14.415, 198.22, 2663.92, 14:18:33.417, 29/07/2007, 9
14.615, 199.37, 2722.23, 14:18:33.617, 29/07/2007, 9
14.815, 200.30, 2780.85, 14:18:33.817, 29/07/2007, 9
15.015, 201.16, 2839.72, 14:18:34.017, 29/07/2007, 9
15.215, 202.03, 2898.86, 14:18:34.217, 29/07/2007, 9
15.415, 202.83, 2958.23, 14:18:34.417, 29/07/2007, 9
15.615, 203.41, 3017.81, 14:18:34.617, 29/07/2007, 9
15.815, 204.49, 3077.64, 14:18:34.817, 29/07/2007, 9
16.015, 205.01, 3137.70, 14:18:35.017, 29/07/2007, 9
16.215, 205.82, 3197.95, 14:18:35.217, 29/07/2007, 9
16.415, 206.41, 3258.41, 14:18:35.417, 29/07/2007, 9
16.615, 206.04, 3318.90, 14:18:35.617, 29/07/2007, 9
16.815, 203.72, 3378.99, 14:18:35.817, 29/07/2007, 9
17.015, 201.45, 3438.42, 14:18:36.017, 29/07/2007, 9
17.215, 198.83, 3497.12, 14:18:36.217, 29/07/2007, 9
17.415, 195.67, 3554.98, 14:18:36.417, 29/07/2007, 9
17.615, 192.64, 3611.93, 14:18:36.617, 29/07/2007, 9
17.815, 190.04, 3668.05, 14:18:36.817, 29/07/2007, 9
18.015, 187.43, 3723.42, 14:18:37.017, 29/07/2007, 9
18.215, 184.73, 3778.00, 14:18:37.217, 29/07/2007, 9
18.415, 182.18, 3831.81, 14:18:37.417, 29/07/2007, 9
18.615, 179.31, 3884.83, 14:18:37.617, 29/07/2007, 9
18.815, 176.81, 3937.06, 14:18:37.817, 29/07/2007, 9
19.015, 174.28, 3988.55, 14:18:38.017, 29/07/2007, 9
19.215, 171.45, 4039.25, 14:18:38.217, 29/07/2007, 9
19.415, 168.43, 4089.10, 14:18:38.417, 29/07/2007, 9
19.615, 165.58, 4138.09, 14:18:38.617, 29/07/2007, 9
19.815, 162.61, 4186.22, 14:18:38.817, 29/07/2007, 9
20.015, 159.92, 4233.52, 14:18:39.017, 29/07/2007, 9
20.215, 157.53, 4280.08, 14:18:39.217, 29/07/2007, 9
20.415, 155.24, 4325.95, 14:18:39.417, 29/07/2007, 9
20.615, 152.97, 4371.16, 14:18:39.617, 29/07/2007, 9
In addition to the spread sheets which are generated, there is also a raw data file which I have used to create the graph below:
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
