i will have a dig around for the receipt but i got mine from the local nissan dealer and they arrived from japan in bout 4 weeks from memory and there was no freight charged as it was an ex-stock item and they just sent it through with the rest of the monthly order.
will try and ferret out the cost etc. tomorrow and post it up as soon as i find it.
cheers oxford
https://www.sau.com.au/forums/topic/179339-weathershields/#findComment-3280738
Apart from looking good I found that they didn't function all that well on my C34, being too narrow and I broke my driver's side one getting in and out of the car.
I'm looking for a set for my M35, which are more useful on this model on account no doubt of the doors being frame types. They're deeper too.
https://www.sau.com.au/forums/topic/179339-weathershields/#findComment-3281055
    • Would be easier to just run the RB25DET gearbox, all you would need to do is have the tail shaft / prop shaft shortened. S15 uses the rear ABS diff sensor for the dash speedo, so you can skip using the gearbox speed sensor.
    • Was the failed sensor by any chance this one? Did it just fail or start pissing on itself? I ordered one too, for fuel pressure monitoring, and now I am hesitant to put it in, hehe. Where did you find a brand one?
    • You'd be insane, when a brand new 8HP is ~$4k, and all the work to put a 6 in would cost the same as an 8 and the 8 is a completely established swap. If you think that getting a cheap Falcon box is going to make it a cost effective exercise, then you're not accounting for the extra $10-15k that the task will consume.
    • any further information on this? also interested in putting a zf6 in behind a rb30!
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
