Hey guys, I am serious about this too, I need a good cheap conversion (easy too) for my old dato ute. Nissan 720 the poor little thing
is a bit tired only having 119, 119, 115, 110 psi and using massive massive amounts of fuel. Should be 171psi.
What I need is some Ideas of engine swap and how hard / easy it will be. Any help would be great.
I am looking for good towing capacity and fuel economy.
Currently its a L18
Current thinking is a
Z24 2.4L out of a navara. I Know for a fact it bolts straight in.
SR20DE
vg30DE
vg25DE
ca18T
L20
v6 common bore (dont really want to go that way)
https://www.sau.com.au/forums/topic/179621-conversion/
If you are going the 2.4 then make sure it is the efi version as the carby ones are woeful on power and fuel. With it being full chassis you can pretty much put anything in legally.
So work out what it is going to be used for and use the appropriate engine.
EG Small cube not good for towing but good on fuel bigger cube good on towing but worse on fuel. You can buy a kit to fit the holden V6 into most utes and they are cheap as no one wants them for anything but a work ute.
The 2.4 Navara engine should also fit quite easy and as long as its injected as in the KA24 and not the Z24 then it should be quite torquey aswell.
https://www.sau.com.au/forums/topic/179621-conversion/#findComment-3272545
might be worth calling Castlemaine Rod Shop, they make a amazing number of conversion kits. you could also try and find something like an owners club or even talk to a Nissan commercial wrecker, sometimes they can be a mine of info on what goes with what because they see so many parts. if you dig enough you'll find someone, somewhere that has done it before.
alternatively, once you've calculated the time and money, and then doubled it, consider buying another ute unless this is something you really want to do.
google is you friend. $1400 for the V6 kit:
http://www.v6conversions.com.au/nissan720.htm
Edited by Scooby
https://www.sau.com.au/forums/topic/179621-conversion/#findComment-3272752
Mate if you want easy get the L20. Dime a dozen too.
Im putting an L18 into my datsun and it literallly just drops in and plugs up.
The only thing youll notice is the L20 wont rev as high but i spose thats not really an issue in a ute.
https://www.sau.com.au/forums/topic/179621-conversion/#findComment-3272778
ok cool thanks guys..... mmm more thinking I can get the v6 common for around 500 including the kit and fuel pump too. If he has not sold it already.
Would love to stevie but I dont want to spend the money I am a tight arss....
Edited by race_snooze
https://www.sau.com.au/forums/topic/179621-conversion/#findComment-3273082
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
