  • Replies 274
Ok list updated again
PM sent to all those who havnt paid yet, people who havnt paid will lose their spots as your spaces are only confirmed when you've paid :rofl:
Those guys have until Wednesday :)
Having never done one of these events before, I wanted to know how much tyre wear you get?
feather the fronts and strip the rears? is grip really from good quality tyres more important that ruining a set of new street tyres.
I will ruin a set if I have to otherwise the sliding set will go on :ninja:
cheers
I think a few people will agree that one of the best ways to go about this is to have grip on the fronts (semis) and wide whatevers on the back...
So who is going down the night before and what not? What is everyones plans?
I didn't ask before because I already have CAMS licence, but is CAMS licence required for this event?
Also for the record...
16. Mark LadyBytes (R32 GT-R or R32 GTS-T) - PAID
is
16. Mark Tuk Tuk (R32 GT-R or R32 GTS-T) - PAID
Nic,
Grip :ninja:
maximum grip - unless you want to get some wicked angles on the pan for the camera's!
Ive used my semis at DECA (same event) and got a bit of wear out of them, but traction was good.
Doof - accomo night before for me!
Well since I lost my lock nut key thingy on the weekend I'll be running on newish streeters. I expect they will still be fine to drive on afterwards even with some sideways action. I think the key is that unlike a track day, you are not out there for long enough on each run to overheat the tyres which is when most of the wear occurs.
Michelle,
yep, CAMS or AASA licence :)
I'm pretty sure Steve knows you guys have paid :)
Thanks
oh and it wasn't the paid bit... I was providing Mr LadyBytes SAU nic (Tuk Tuk) so he can use his own ID rather than being Mr Ladybytes LOL
You shouldn't get that much tire wear at all - assuming you are trying to drive well - as opposed to drifting the course which might be fun but is much slower. You should also remember that each run will only last 2 minutes max and probably much less. You'll spend less time "racing" than one session in an average track day. In most cases the tires won't heat up and get sticky the way the would after a few laps on the track. Most people who race these types of event run tires specifically design to warm up very quickly - more so than the average semi.
I've run street tires (Federal 595s) at both DECAs and don't think the disadvantage to semis was anything like on a real track. If you're uber good you might notice the difference. On the skid pan you'll find out quickly it is all about driving skill.
Alright good :( Where are you staying?
Need more peoples to answer! I wonder what Wayne-o and Kasey-Bird are doing... As well as Jen and Nige...
Hello Doof-mister, :)
We are cruising down AM on the day!
(Gotta a party on the evening before)
See ya there! :D
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
