I am in search of coil packs for my 1996 nissan skyline R-33 Gts-T. mine are grounding out and I would like to go with some aftermarket ones but do not know where to find them or who makes them for that matter. I don't want to have to d a lot of wiring revisions to get them in either I would rather pay more for some that plug directly in and make it clean and simple. Any help is greatly appreciated.
Also I am looking for a good shop to buy a RB26DETT crank, conecting rods, pistons, rings, bearings, wrist pins, and oil pump from so that I may stuff them in my RB25DET block.
Final thing I am looking for is a goos solid set of cams and valve train to put in the top end of it, I want a smooth idle and nice smooth power curves, any suggestions there would be gratly appreciated as well.
https://www.sau.com.au/forums/topic/179882-coil-packs/
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
