Hi all,
I need to get a roadworthy for my GTR32. Need one where they aren't picky on things cuz it's quite modified, but it has modification plates. It's just the stuff like it has no ABS, no aircon, etc etc. Basically I need a RWC no matter wot before this saturday!!! Inputs please!
Cheers~
Edited by J-Boy
https://www.sau.com.au/forums/topic/179885-need-rwc-for-modified-gtr/
i got my car done at boike autmotive at kuraby, they didn't seem to worry too much about mods but they did look at the safety items, like steering, braking, drive train lights etc. no so worried about exhaust, suspension i.e. coilovers.
If he doesn't need the RWC, but would prefer one, and your going to get a dodgey one.. what is the point in getting one at all LOL
It's not that hard to get one though, just find a dodgey looking place and tell them you want to transfer the car from your dads name to yours asap, works a treat ;)
ACE auto in Murarrie did mine.
Although my car was fairly stock, they did not have anything to say about the following.
18" non standard wheels
Sports steering wheel
HKS blow off valve
Lowered
Eyelids over headlights
Cat back exhaust
They also looked after the car quite well, no grease or shit on the steering wheel or dirt in the carwhich is what you usually get after any mechanic has been in it.
There really are no "relaxed" places anymore, believe me I looked as I was really worried about the above.
They have all been shut down or will only do it for really really close mates.
Thanx guys, didn't need one in the end~ car's sold~
Even so, to clear up something for everyone.
Roadworthy does not depend on modifications done. There are certain guidlines that they must follow. Other than that, as long as the car is essentially safe, it should pass.
If you have a blue plate for your mods, then they should not even need to be checked in a roadworthy
Silly things pass like:
You can have absolutely no baffling left in your rear muffler but if it doesn't exceed noise limits and there are no holes then it passes.
No spare needs to be present.
Only driver's side window has to work
Oil leaks are ok as long as (after cleaned) they do not form one drip within 10 minutes.
Surface rust is ok but can't poke anything through it.
As you can see it's not like you have to have a new car to pass.
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
