Picked this up last night.
It's a little titanium knob which is countersunk pretty deep, so it should shorten the throw a tiny bit. It's also a good size. Same size as those plastic nismo ones that look like they're curtain rod ends. So it's not like those ugly, large, and bulbous Momo pieces of crap.
It also feels like it's got a bit of weight to it.
I haven't installed it yet though, as my car is still at the panel shop. Once I get it back, I'll install and post more pics.
https://www.sau.com.au/forums/topic/180128-apx-titanium-gear-knob/
Yeah I was considering the ARC one but need to know how much the APX one costs.
Also when they say "M8X1.25" does that mean the knob will fit a shaft 8mm in diameter with the thread being 1.25?
It's weighty so I reckon it might be "Titanium-look". But hey, can't go wrong at the price I got it for. :D
Also, I reckon a few people would've looked at it and said, "ooh nice ARC knob"... But now that I've posted this thread I've ruined it haven't I. lol
Genuine question: Whats the deal with titanium gearknobs?
The whole point of titanium is so that it weighs less right?
But with gearknobs you want a bit of weight in it so that your shifts feel more solid, so is the titanium only for the look (and strength)?
I have a DC2 type-r titanium gearknob in my Civic and it is definitely at least as heavy as the stock one. It does give a nice feel though :whistling:
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
