Hey guys new around here, joined as im looking to get a skyline in very near future (as soon as i find one i like). Would like to buy local but if nothing comes up will probably import through JDS in Hobart so if you have a R33 or R32 GTS-T for sale for less than 14ish thats relatively tidy i'll probably be interested. Hit me up with a PM or post in here and i'll get back to you to come check it and have a chat. Also can really only deal around Hobart as dont have any time to head north. Thanks!
https://www.sau.com.au/forums/topic/180446-wtb-r32-or-r33-gts-t/
Hi man
There is alot for sale in tas r32 and r33 gtst.A bit harder to find good gtr thow a couple i had a look at in tas were rough so took to melbourne.Lots of veriaty and negotionable.Came back with a good bargin.
stuart
Hi man
stuart
Hey Stuart,
Hows ya going, So what did you get? post up some pics
cheers
Leigh
The pearl red r32 Wogboy Jnr has up for sale is a bargan for the car. plenty of work done and a very tidy car. plus who else has a nice bright red 32 in tas?
I can think of 3 others straight off the top of my head :thumbsup:
Toff's 4 door is a bargain if your after a tidy car with some mods, you wont find a better car here or elsewhere for the price.
If you think you can then your kidding yourself :nyaanyaa:
I can think of 3 others straight off the top of my head :laugh:
If you think you can then your kidding yourself :P
:wub: fanks for the kind werdz ben, its not perfect , but im very pedantic :blush:. ive just ordered a fmic and im in the middle of getting a safc for it, and its already got the rest of the stuff needed to make around the 200rwk :thumbsup: . i wish i could keep it tbh, i love driving it :)
Yeah, wouldn't mind it as a tow vehicle to get my track 33 to the races.
:nyaanyaa: , i have a nice falcon you could do that to :blink:
Lol no luck yet, everything ive looked at is great but just not exactly what im afterm i guess im a bit picky.. The above looks promising though :angry:
Yeah i was the same when i was looking for my first 32.
I was going to tell you about Josh's car, worth a look :thumbsup:
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
