Hi guys,
finally had my engine swap work done to my '71 240z,
Have put in an rb20det w/gearbox, cooler, eng. management system, surge tank, fuel pumps
Looking at getting the exhaust done for it in the next few days and am curious on any thoughts in regards to a size.
I'm thinking 2 1/4 - 2 1/2", with a hi-flow cat and effective muffler. I've had a couple of friends tell me to go 3", but i'm not convinced its going to really help the performance of the car, moreso just making it louder than i want.
Have had a search through the forums with not much success, sorry if i'm repeating a gone over thread.
Any advice on this would be greatly appreciated.
Thanks again
https://www.sau.com.au/forums/topic/180588-exhaust-size-query/
yep :cheers: fully agree
3" is best, a 3" will sound nicer, deeper, it won't be louder if you do it right
Put in 2 mufflers, or a muffler and a resonator, one just after the cat, one at the end of the car
It'll sound very nice
3" will drone like a m$%()#*(er, I'd be going to a good exhaust shop and saying "i want maximum power for minimal drone". 3" is very hard if not impossible to stop droning, it'll give you headaches, did in both cars i've owned with it (and this one is only a catback). imho
there is this new invention called mufflers. if you get good ones they will cut the noise and drone. get a good centre muffler and a nice oval muffler on the rear and it should be all good.
Bit off topic, but what brand resonator's do people use? I mean theres plenty of info on mufflers but resonators seem to be lacking on info like cfm flowed and noise reduction. Anyone recommend one?
trying to find a good 3" resonator is hard. most are too skinny through the body. just get a 3" off centre-centre oval muffler put in the middle, then a either a straight through 3" oval muffler on the rear, or a 2nd off centre-centre muffler for the rear.
Maybe dont be a tight ass and get a decent exhaust made?
Mine have never "droned" and they were 3" 3 times, and soon a 3.5"
Drone is a resultant from harmonics down the length of the system. Proper resonator / muffler choice should eliminate drone in ANY pipe size.
SMB are really popular in the rotary world, were a 3.5" system, comprising of SMB cat and muffler, bring 400hp turbo setups to legal limits, with no drone.
also the wall thickness and material of the pipe used has a bid effect on the sound and any harmonics (drone). generally mild steel is sold in thicker pipe than stainless and the mild generally sounds a bit nicer with less resonance.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
