  • Replies 273
It's Vanilla latte`... And in fact im going out for coffee tonight and might order one haha as Per normal
When you say "going out" do you
A. roller blade
B. Razor scooter
C. pushbike
D. skateboard
E. Other
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
