The jerking on downshift is basically independent of pucks. It's all a matter of driving style. The blip is called "heel-toeing'. The reason you get the jerk is that the engine and gearbox are not spinning at the same speed for the gear you are selecting. Heel-toeing matches the engine speed to the gearbox (road) speed.
https://www.sau.com.au/forums/topic/180905-5-puk-or-9-puk/#findComment-3289078
3 puk - http://clutchnet.com/photos/3button_solid02.jpg
5 puk - http://www.mpautoparts.co.nz/images/PukPanel.gif
as u can see, the more puk's the greater contact area on the flywheel and easier to drive it will be.
https://www.sau.com.au/forums/topic/180905-5-puk-or-9-puk/#findComment-3289966
feel is best described as where in the peddle travel the clutch starts engaging and how suddenly.
With OEM clutches... they have no feel really... once you get a button you'll learn all about feel for the clutch :rofl:
thats for sure..
I use an Exedy Hyper Carbon Twin plate.....kinda crazy if u drive it in heavy traffic.
https://www.sau.com.au/forums/topic/180905-5-puk-or-9-puk/#findComment-3292113
ok.
i guess i have a final question.
Out of the clutches below, which one is the easiest to drive??? and when I down gear, there will not have a shudder...
-5 puk ceramic button
-9 puk ceramic button
-cushion button
select one from the above. the main important point is that I do not want the car to shudder when down gear...
Cheers. :thumbsup:
https://www.sau.com.au/forums/topic/180905-5-puk-or-9-puk/#findComment-3296889
Hear this
ALL CERAMIC/BRASS MATERIALS WILL SHUDDER ON DOWNSHIFT IF ENGINE REVS ARE NOT MATCHED!!
Its due to the nature of the materials used...doest matter how many pucks or whatever. if you do not rev match, then your pretty much slipping the clutch everytime you downchange.
But, as for most driveable.. a 9 puck cushioned button will be the most driveable
https://www.sau.com.au/forums/topic/180905-5-puk-or-9-puk/#findComment-3297307
Hong, going back a few posts a cushioned clutch has nothing to do with a sprug center rather a cushioning between each side of the clutch plates. A conventional button uses a single sheet of metal with puck either adhered or riveted to it. The Cushioned plates use two plates with a "spring" in-between. This "spring" takes the initial shock of the engagement rather then other driveline components such as gearboxes and diffs :laugh:
Bacially if the vehicle is mainly a daily driver, and a puck clutch is your preference, I would strongly suggest using a cushioned item.
The sprung center is purely a sound/vibration dampener.
If you need any further information or pricing on Genuine Exedy Clutch Kits drop me a line.
https://www.sau.com.au/forums/topic/180905-5-puk-or-9-puk/#findComment-3297558
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
