Nice shots. Like your interior lighting theme. Well done.
Only thing I would suggest is to modify that front bar, get rid of the number plate support and the white cross piece behind it all together. That way you have a larger opening for the intercooler and would look nice and neat as well. Its just too much going on at the front with that bar if you know what I mean. Other than that I like the way you keep it stock look wise.
thanks for the kind comments guys.
And the front bar, i don't want to cut it as it's a genuine Nismo bar...but i might if i find a shop that could do a decent job.
And the 2 things above the a/c are Power Meter and Blitz SBC iD
Nice ride mate. One of the cleanest 34 gtt's I've seen too.
Thanks.
The interior has a few scratches oin it however...but it's a 10yr old import so..
I'll be searching for some interior parts though to make it look "nicer"
where did you get your dash lights change mate?they look nice
I purchased the LED's off 666DAN and installed them myself.
Pretty easy once you do it.
Nice car Paul!
Really love the interior. Was it difficult to pull the dash out to change the bulbs? How many bulbs did you change in the dash?
Dash lights r real easy to install, few screws, pop out the dash partly, change globes.
Nice engine cover Paul, hahaha...
Btw. where did u get the backlit lights for the climate control panel and was it easy to change? Mine comes green factory std, i was trying to find a blue backlit to match the rest of my blue LED dash. PM me if u can.
Cheers.
Cheers.
Yeah..nice engine cover :laughing-smiley-014:
As G_Force mentioned, dash lights are easy as well.
But it did take me about 40mins first go to do it all.
Now it takes me 10mins to change a bulb :)
The backlights i sourced off Dan and it was pretty easy to change. And trust me...if I say it's easy, anyone can do it.
Nice R34, I like the V35 rims that fill those guards nicely :P
thanks mate.
I like the rims too.
Would prefer Work SP1 or CE28N or TE37, but these will do me fine.
Loving the interior.. i was thinking of getting some lights as well.. how much did it cost? how many did you change? could anyone who's already changed the dash lights possibly show the steps to DIY?
The lights i changed myself.
Have a search for DAN666 posts for his LED's.
u need 4 for the dash and 3 for A/C + 3 for centre gauge console + 3 LED's for the LCD in A/C
Not that expensive to get the globes delivered.
Looks nice mate.
Thanks :thumbsup:
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
