Hey Anton
Sarkis' 'group buy' did go ahead in a sense, but it wasn't really a group buy as such. It was pretty much - those are the prices, take your turbo down there and get it done at your own will.
I knew a few people who went ahead with sarkis' buy who borrowed housings off me so their car wouldn't be off the road for as long
I saw some of the turbos that came back and they are a great piece of work.
Nice work organising this buy. I might be in touch with you/john shortly - got a some projects that I might building
hey Chris, yeh just thought that if we do it this way we can get people together and get it at a discounted price. i might buy one of your vg30 housings of you, but ill see how things go. He offered to do it for $1250 straight up and $1100 if we went as 5 and did it. If we get 10, he might even drop it to $1000, which is a good price IMO
do these use the stock oil and water lines, as they are? or do they need to be modified?
is there any chance that in the group buy, there would be an option for the ball bearing version and just pay the difference on top of the journal bearing group price?
if so, what price for bb?
Edited by Munkyb0y
Monkeyboy, if these are like the precision turbos ball bearing ones (should be the same - theyr'e both garett catridges), then john supplies you everythign you need - washers, new banjos, banjo ends, gasket for turbo, oil drain gasket - everythign you need.
Monkboy: i know you use the existing oil and water lines, but ill confirm if they need to be modified at all. irrespective, if they are required to to be modified, all work is included in the price. Ill also try to find out what price he can do for the ball bearing and get back to you tonight.
Sexypete: so does that mean your in mate?
hey i just got a precision high flow ball bearingturbo for my r32 and its really good. i have some minor issues with my car but its definately worth it. the car is making 16psi at 4000rpm. but i did have to get new lines made up for my turbo and it would of been better if i was to buy a hks gtrs. if you are going ahead with this please make sure that it does truly bolt up or all the modifications required are listed.
I'll explain based on the ball bearing model. Like i said above, as they use a garett catridge, the bajo bolts are different sizes.
John supplies new banjos for the water and the oil.
The new oil banjo works with the stock oil lines.
The new water banjos use a different size water line end. John supplies this.
For those people getting the turbo installed by a workshop, this will be no difficulty for them.
For those people isntalling it themselves, there are a few different ways to do this. Get the new banjo end tig welded onto the stock lines to replace the stock sized end. This is perfect - will look like stock, be as strong as stock. Most places will charge about $20-30 for this because its only 2 welds.
Alternatively, you can take your lines off, and take them down to pirterk and get some braided lines made up - costs about $80 each.
I prefer to just get them tigged
sorry, i dont have any dyno sheets, but if you wanted a ball bearing, you'd be looking at at least $1500. Also to save youself hassle, if you can provide your own lines, they will be modified to fit straight back on
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
