I read the specs on the stagea a while back as I am havin a good think about getting one someday, and wondered what they perform like in the everyday carpark scinario. Turning circle in the specs = 5.3 metres, and that's huge! Can you get a steering rack that makes the turning radius smaller?
https://www.sau.com.au/forums/topic/181049-stageas-in-carparks/
Huge? are you used to driving a barina or something?
Turning circle is hardly a factor i'd decide whether a car is good or not. I mean, I have a skyline - same gear. I have never found it a PROBLEM. e.g. I don't go oh shit, ran out of steering lock when trying to park...
In answer to your question, yes you can
Barina - no. Ford Laser - yes. it has...or should I say - had, a nice small turning circle. Thanks for answering the question too. I don't rate it steering as a major factor, but thought i'd throw the questions out there.
Well, as a direct comparison to my last car (eb falcon) I think the stag parked beautifully. Before you compare it to a laser, you may want to compare the wheelbase and interior space too.....
The Stagea has a pretty decent turning circle considering the fact that there are drive-shafts running to the front wheels too (unless you go for a RWD version). I came from a Corolla, and my old man still has a 2003 Camry. The turning circle on the Corolla was great (obviously, because it was a small car), but the Camry's turning circle is worse than my car's...
One thing with the Stagea is the rear overhang, but what's good is that the rear window is almost vertical, so it's pretty easy to judge how much room you have behind you if you reverse park into a spot. It's also good because it makes the load area much more useful, compared to a hatchback or a wagon with a steeply-sloping rear window area.
FFS you buy a car and you are worried about the tunring circle? Forgive me for saying this but how long have you had your license for?
In a car thats 4wd the turning circle is going to be always a large one. It doesnt mattes wheter is a sedan or suv. Why? Like they say theres Cv joints in the front wheels that drives it. Thats the factor that limiting the turning circle. Get it?
Driving skills is all you need to drive in a car park. One advise when driving such a long vehicle always go for a rear entry :P:D . Which means rverse in instead of parking head in first try it.
Rather than start a new topic i'm going to follow on with a similar question:
How's the reverse parking go with the Stagea? I'm coming from a Subaru Liberty Sedan and it's easy enough to park in tight spaces - I"m guessing Stag's aren't too bad in that respect?
Like I mentioned above, Ian, having a good-sized rear window and an almost vertical tailgate helps heaps. You know that if there's roughly 2ft to the rear window from a wall, that roughly half of that should be left for the bumper. Of course, if you're gonna open the tailgate later to get the shopping in or whatever, don't forget to leave more room.
I find it enormously better than my 70 series Supra in carparks, for the simple fact that the Supra's doors are about 3 km long, and you had to take at least 6 months of yoga before even contemplating using anything but the aerotop for ingress/egress. Sure, the turning circle is a little wider than a Lotus Elise, but it's a Large car!
Ive never had an issue in a carpark and ive had to park in some stupid stupid spots.
On another note, want more lock, get aftermarket tie rod ends and adjust them for more lock, then a wheel alignment to adjust toe.
Otherwise, remove the rod ends and insert some spacers, aka washers, when screwing the rod end back in. This will do the same thing but in a less safe more borro drifter kinda way....
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
