pending the ecu u use, u'll need specific injectors. i.e top feed high impedence or top feed low impedence
the rb25 power fc will require u to run top feed high impedence :rofl:
also, i think the only area ull have fitting worries is with the collars on the plenum where the injector goes in. subzero should be able to look after that though :(
thanx guys
ecu is wolf v4, im sure it can be retuned to accomodate top feed injectors.
as with the physical fitting into the plenum i think it may fit coz subzero use the standard runners
anyone have a definative answer??
make sure u let ur tuner know what injectors ur using, as he'll have to adjust the injector drivers to suit
