My car has a very strong petrol smell when idle, its not leaking into the cabin, but if i am just starting up the car and have the door open, or idle at a drive through with the windows down.. it pretty smelly. the exhaust is not smokey or anything :S
is this normal..
its my first car so ive got nothing to comare it to but mums magna and dads astra dont smell this much.
https://www.sau.com.au/forums/topic/181257-strong-petrol-smell-when-idle/
is this normal..
I am driving a NA S2 R33 as well, experiencing similar problems when im idling especially when the engine is cold...till today, i cant figure out wats wrong with it.....didnt notice any leaks from the injectos though
hows ur consumption like?
btw nice S2 u got there
thanks, consumption is excellent about 450km per tank. and yeah i must agree when its cold its a lot worse. i have no modifications except a muffler tip.
it doesn't seem like a big problem, i can live with it. just was curious to see if any other people get the same thing
Mine smells only on cold start, once its warm you cant smell a thing
I presume because the ecu runs it rich while warming up
I had leaking injectors also but i got that fixed, before that the petrol smell was always there.
is the smell in and around the engine bay? or unburnt fuel coming from the exhaust?
if it's the later then you're just running rich idle
it is the later
very much from the exhaust
Mine does it too, S1 33 n/a, when i hop out i sometimes get a huge wiff of it. usually near the driver side door i smell it more..
I only get like 300k's a tank prob the way i drive though and alot of little trips
yeah my old series 2 used to do that, my new one doesnt, both n/a
it used to stink like rotten egg's/petrol.
no idea what it was as my car was completely stock with under 100,000k's...aparently
i put on a 3 inch cannon onto the stock system and this made it 100 times worse. i think the ecu makes the car run rich to protect it from something..as you can tell i dont know much about cars.
i get around 350k's to a tank....i think.
at least i know im not the only one.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
