  • Replies 80
wow, never thought my thread would go there so fast. ok so one more question. i have an aftermarket hks mushroom filter on the stock intake tube. my blow off is really loud. ive got a fmic and intake head and catback. the rest is stock. i kinda just wanted to get rid of the stock pipe whre the bov sits and move the bov. i kinda also like the flutter sound.
abu, what were you talking about flutter earlier
I think you mean you want to have a flutter sound right?
remove your bov (2 bolts, 2 clamps)
cut out a piece of sheet metal the same shape as the base of your bov and drill the holes for the 2 bolts.
put that under the bov and plug it all back in as it was.
now you have blocked off your bov and it looks stock.
you will get flutter.
then, once you get annoyed of the car not acting as it should, you can easily just remove the plate under the bov and be back to normal.
why don't you just stop the standard bov leaking and leave everything the way its meant to be, bov's and flutter just mean more unwanted attention which at the end of the day will cost you more in $$ with the cops when they start defecting you (not to mention the wank factor)
or just buy the GTR bov and fit that like everyone else has said, people on here don't come on just to hang shit on everyone (dunno bout everyone but meh..) and you ask for answers and people have given you the right answers...
the best thing about SAU is that no matter what your question is, someone else has already been through the same thing, they are talking from experience, f**k the atmo bov off, don't block your bov cos you'll end up with the back of stock turbo in your muffler
gtr bov is plumback.
it can "blow off" more air than the gtst one.
but the gtst one is also good for well over 200rwkw.
GTR's have 2 bovs as standard.
they sit in the drivers side front guard.
gtst owners usually upgrade to a single gtr bov.
each gtr bov can breath more air and for this to happen, the OUTLET is larger in diameter.
to fit to a gtst, it will bolt on to the stock gtst bov position, but you will have to get a larger diameter PLUMBACK line.
NO, you can't vent the gtr bov to atmo.
not having a bov will not break the back wheel of your turbo.
if anything, it's the front wheel that "could" be damaged.
No the stock gtst ones don't leak after 10 psi.
No it doesn't matter which gtr bov you get.
expect to pay about $150 for the pair or half that if someone is selling one.
http://www.skylinesaustralia.com/forums/in...howtopic=181922
Or you could buy this!
that is old skool
been around for like 5 years.
why would you buy it when you can get a screw and stick it in there yourself?
the little hole is there for a reason.
it helps to open and shut the bov faster.
if it's blocked, the car feels a little more jerky on the transition point from boost to vacuum.
as in when you back off from the accelerator in a gradual fashion (like when you drive on the street)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
