  • Replies 94
Yeah i feel the interior is pretty good considering it was designed in the 80s and went through to 94, compared to the 33 i think the 32 dash has a racier feel aswell
haha hey mate, ill bring my farther and friend along tom night aswell
https://www.sau.com.au/forums/topic/181578-gtr-sale/page/3/#findComment-3300550
stock power should be around 200rwkw, but quickly goes up to 240-260 with boost controller, exhaust and a tune/re-map =)
after that, you decided what power you want to get to hence what turbos you want, and start doing supporting mods for them till your ready for the turbos... then the sky is the limit =P
edit: well, thats my plan at least... and im pritty sure thats what ALOT of the other gtr owners do as well
Edited by Fishpaste~
https://www.sau.com.au/forums/topic/181578-gtr-sale/page/3/#findComment-3300559
oh ok cool.. how easy and price wise is getting 260 awkws in a 32 gtr
https://www.sau.com.au/forums/topic/181578-gtr-sale/page/3/#findComment-3300571
well, i'm sure mine is stock, with a few little things done already (exhaust and ECU) and its getting stock kws
so for me it'll be a boost controller: about $450 fitted, Hi-flow CAT $380 fitted and tune $200... so about $1000 and i should see those kind of figures depending on the condition of the engine (i think boost worx charge the same amount for a tune or a re-map, but would have to double check with shaun)
if you check out the wasteland sinful got her 32 gtr to 260 with just a power fc from what i can remember (probably also a boost controller)
https://www.sau.com.au/forums/topic/181578-gtr-sale/page/3/#findComment-3300611
I would imagine a full exhaust from turbos back, boost controller and an after market ECU + tuneup and around 1 bar of boost would get you damn close to that mark ?
Infact, u might not even need an after market ECU ?
https://www.sau.com.au/forums/topic/181578-gtr-sale/page/3/#findComment-3300612
PM Hostile from on here as he is at 300+ rwkw and has spent hardly anything.
260 rwkw
Turbos back exhaust
Pod filters
Fuel pump (not necessary, but good insurance)
electronic boost controller set at about 18 to 20 pounds
PFC
z32 airflow meters
possibly upgraded front mount
This will get you really close to your 260 rwkw and the GTR will eat your gtst through the hills and in a straight line.
Watch out for the oil pump in 32's as have seen to many dead 32 motors duel to the oil pump failing.
If there is something i have missed please add to the list if you think he does or does not need something.
https://www.sau.com.au/forums/topic/181578-gtr-sale/page/3/#findComment-3300630
damn thats pretty impressive!!! hmmm 260 at all 4 wheels, lighter than a 33 all for around a grand....
https://www.sau.com.au/forums/topic/181578-gtr-sale/page/3/#findComment-3300636
Yep Shaun you spot on...
As I said before mine has a later model RB26 that came with HKS cams, bigger injectors, N1 spec turbos and a fuel reg.
Dyno at stock boost was 233kw at wheels
Put in power fc... tune at 13.5 psi= 251.4kw at wheels (conservative tune waiting on better clutch and boost control)
Added blitz sbc spec R and twin plate clutch= easy 303.5kw at wheels on only 18psi.
I still have stock dump pipes as well!!
There is no comparison between GTR and GTS-t.... TOTALLY different driving experience.
There is nothing like stepping off the clutch at 7000 rpm and launching a GTR.... everything else disappears in the distance behind you!!
https://www.sau.com.au/forums/topic/181578-gtr-sale/page/3/#findComment-3300658
did u own a gtst before ur gtr?
https://www.sau.com.au/forums/topic/181578-gtr-sale/page/3/#findComment-3300676
My old R32 gtst had 237rwkw....my new R32 GTR has 208rwkw....and the GTR still feels better. Basically alot more torque and power straight away.
Will have 300+ in the coming weeks. :PBJ:
Ryan
what have u done to the stock engine to get up to 300??
https://www.sau.com.au/forums/topic/181578-gtr-sale/page/3/#findComment-3300770
No comparison....
The first thing you notice in a GTR is the amount of grip, or the feeling of stability.
The GTS-t feels a lot more twitchy where the GTR just sticks. You often don't feel like your pushing the GTR until you glance at the speedo!! It is just effortless.
https://www.sau.com.au/forums/topic/181578-gtr-sale/page/3/#findComment-3300886
    • Yeah, I guess its pretty easy to get to if this doesn't work. Just wait till next oil change and pull it out. I am going to have to do the oil pan gasket soon and thought I'd just replace it while I was there.  Thanks
    • All that matters is you're safe and you were able to type that post. Hopefully heaps of parts you can recover for the next shell.
