ron: he isn't adjusting his cam timing, only his ignition timing. don't confuse him.
flash89: a timing light and small socket to loosen off and adjust the cas. maybe an allen key to rip off the coil cover so that you can get at the no1 coil. Depending on the timing light you are using you might have to get a plug lead off another car, and fit it between no1 coil and no1 spark plug to get a correct pickup. Thats all you will need.
On a motor warmed to operating temp, an rb20det should be set to 15deg. Thats looking at the timing marks behind the crank pulley viewed from the top. Same idea as setting the timing on an old carby car so get someone who would know about those to help you.
The only funky thing is the probable need for the coil lead as with the timing light pickup signal, using the provided loop of wire near the ignitor on my motor produces a reading of about 40 deg, instead of 20deg due to how the ignition system operates and how the timing light operates.
hope that helps.
james.
https://www.sau.com.au/forums/topic/181729-timing/#findComment-3305147
the consult timing does not take into account whether the distributor/cas is set correctly. so you CANT use it to check that timing is set properly. the timing value is an ECU output, not an input, it doesnt know if you have advanced or retarded timing at dizzy/cas (which is why you can actually advance your timing without ecu compensating)
all you can use consult for is to use the timing lock mode (i think conzult free has this) to make adjusting timing easier by making sure the ecu doesnt make timing jump around. you then have to confirm that the timing light reads the locked value (15?).
https://www.sau.com.au/forums/topic/181729-timing/#findComment-3313329
well i fiiiiiinally finished my 100k service and she started beautifully first time (well first time after i pushed the CAS plug back in properly...) - thought i did have to tighten the distributor belt cos it was whining like my girlfriend after i've forgotten an anniversary or something.
i bought a $20 timing light from supercheap. so to do the timing i just take the coil pack cover off, connect the timing light so it's in 'serial' with the no.1 coil and point at the harmonic balancer while the engine is running and make sure it matches up with the 4th mark on the balancer?
if so, i might just dab a bit of paint pen on that mark to make it easier for me to spot yeah?
it's odd that nissan made the 0 mark orange and not the 15 mark....
any feedback on this technique? didn't want to start a new topic cos there's a few out there but none of them with definitive answers.
https://www.sau.com.au/forums/topic/181729-timing/#findComment-3337305
Mine does the same.
Try double looping the wire through the timing lights pickup; does the trick for mine. :closedeyes:
https://www.sau.com.au/forums/topic/181729-timing/#findComment-3345767
ok, I'll give that a try..
Have to redo my timing before I can drive it again. Pulled the cas and timing cover off to inspect and test in preparation for my parts purchases. Stock bumpsticks unfortunately. Compression tests across the board were min 175 max 182.. thank god for that.
New 2860-5's and tomei b's to buy now.. :blink:
https://www.sau.com.au/forums/topic/181729-timing/#findComment-3346794
:P
If its reading 30-40degree's then double looping the wire tends to get the ignition read out correct; its timing light related.
If it reads 15degree's off the bat, the cas is in its usual position and the car is idling nice its 15degree's not 7/8.
30-40degree's on idle with the car idling well is impossible.
Its simply timing light related. Don't worry about it if yours isn't reading 30-40degree's. :unsure:
https://www.sau.com.au/forums/topic/181729-timing/#findComment-3347052
:P
but i have had it at 30 and 40 and it runs ok?
really in all the fiddling i have lost the original setting having moved the cas to all sort of positions
maybe it should be 30 and ive made it go to 15?
https://www.sau.com.au/forums/topic/181729-timing/#findComment-3347087
If its a true 30-40degree's then once you touch the accel and it pushes in another 25degree's advance that would be a total of 65degree's advance and you would definitely feel both the lack of power and hear the exhaust as it slightly misses.
Idling on much more than 20degree's idle becomes rough and it begins to have a slight half miss/pop.
If your cam timing is correct set the bolt centred with respect to the cas and that is approx 15-20degree's advance.
If you have to dial in what looks like excessive advance or retard (hence not near centre) then your cam timing is out.
Have a play you will learn to hear how advanced or retarded it is running. A few tell tale signs are how smooth the car is running, idles lower, idles higher, does it pop/have a slight miss & the note of the exhaust. :P
https://www.sau.com.au/forums/topic/181729-timing/#findComment-3347102
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
