Didnt get the GTR clutch fixed in time, so I took the Datto out.
15.972 @ 83.90 mph
5 runs learning new setup. Car felt very strong then;
On my 2nd qualifying run I sprung a oil leak on my oil pressure t piece, snapped fitting on the block. So I had to go back to town to get a thread easy out. Fixed and drove home no worries.
Guest Rexlr8
13.6@107miles
spun wheels through first and second"
Pretty good dude! Street tyres or semi slicks? If i didnt get my pay screwed up ( 200+ short ) i could have had a go. I'm just scared i'll leave my box behind at the line lol. 5spd isnt built for the strip.
You said you did 8 runs, could you of done more? Or is that all you were able/aloud to do. And what did you end up paying for the day.
hey u mob havnt bin out 4 a while prob wont be out much anymore im having major missfire issues around 4500 rpm under high boost but only if i plant it. if i slowly feed the throttle its ok but under load it sounds like it hits the speed limiter and dies in the ass. so sometime this week im goin 2 apply at jimmy's work for a job and start savin some good money then the real mods will start happening lol, oh pretty pissed off 2 i was drivin down the road and heard a noise like a rock or a stick got home and had a look and found a finger sized hole in my sideskirt just yet another thing i will have 2 get fixed owll lol. catch ya's
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
