Guest Rexlr8
I dunno craig, once I get traction I catch him faster than you
True? Well in that case lol. I'll see what i can do then. Tell you what, if only we were racing on a day like today. 19 on my dash and damn its good.
Haha! Jimmy man, never underestimate an excel! Just ask Cammo :(
What driveline clutch/gearbox/diff is the mr2 running? It is very rare to see any quick ones on a dragstrip in australia, they can be very fragile.
Quickest mr2 in australia currently is a sydney '88 1.6l running 10.66 @ 131mph on a 225/60/15 tyre.
If jimmys korean rocketship is auto I will buy him a carton if it can beat my cruiser :P
dang ozzy, its manual!!
hey man, can you help me move my car sometime this week? or maybe next week but soon..
just gotta put the suspension back in and find some wheels (just for the move), but would like to borrow you and your trailer if thats ok..
cheers
my car all dun getting picked up on wensday be here on saturday next week redline at 8000rpm they tuned it 4
300rwkw on 16psi
low boost 246rwkw on 10psi
and turn my boostcontroller off it made 205rwkw on 7 psi
so im gona get sum semi slicks and see wat i can do down the quarter
thank f**k 4 that finally dun almost been 6months
hopfully end of year ill get gear box and clutch and retune 4 400rwkw+
racing your cruiser ozzy?
Nah just the gtr for bracket racing. BK got his clutch in the VSPEC today, so hopefully we can run some 11sec battles.
Will keep my slow cars for the street meets.
Good news Fab, some 255/50/16 M/T Et streets would be the go. Plenty of rwd skylines have got into the 10's with these, so you should be able to get a 11 sec pass straight up on 16psi.
Guest Rexlr8
Nice work Fab man, should be good for you to jump into it again. Now you can match your previous 1/4 slip to a new one when you race it.
Power figures pretty close to yours kurt, cept the boost is lower or what? Either way, another quick car to be on the street :yes:
Edited by Rexlr8
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
