I was going to try here.
http://www.plmsdevelopments.com/realtime.shtml
when i can find a reasonably priced z32 ecu that is.
Are these the same guys that you've tried.
If so doesn't look to promising.
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3330794
Do a google search, live edit is free however all of the other hardware is not...
It is morre expensive than the nistne setup, and not as good.
so i'll keep waiting also.
on a side note, anyone have or know where to buy an z32 ecu at a decent price. I mean $400for a 16-17 yr old ecu seems a little rich.
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3332978
We've now got working R33 tuning boards available, will have the Nistune update from Matt this week to see how the nistune software goes with the RB25, can't wait...
I'm using NRE from the same guy who wrote LiveEdit but full real time map tracing and emulation...
R33 Remap - Example
Standard R33
FMIC
040 Fuel Pump
3" Turbo Back Exhaust
HyperGear TR43
STD AFM
STD Inj
STD Air Box
Remapped R33 ECU - 45 mins of dyno time
More to come with upgraded injector and afm
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3335522
At the moment they are quite expensive, and yes quite difficult to install, would only recommend advanced electronics techs attempt this, need smd experience and equipment... I'm still trying to work things out regarding fast turnaround of supply and install with base maps...
Edited by Dr_Drift
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3335675
Hey Guys
Good to hear news is spreading.
And sorry for the no reponses to email. Just found out last week that AAnets mail server has been really dodgy and not passing on emails... and I just thought it was getting a bit quiet until Pete L told me customers were able to contact him through his site.
Not happy but not much I can do now until they fix it!
Please contact me [email protected] in the meantime if you wanted to know any thing about the boards or place an order etc.
thanks
Matt
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3362228
