I was going to try here.
http://www.plmsdevelopments.com/realtime.shtml
when i can find a reasonably priced z32 ecu that is.
Are these the same guys that you've tried.
If so doesn't look to promising.
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3330794
Do a google search, live edit is free however all of the other hardware is not...
It is morre expensive than the nistne setup, and not as good.
so i'll keep waiting also.
on a side note, anyone have or know where to buy an z32 ecu at a decent price. I mean $400for a 16-17 yr old ecu seems a little rich.
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3332978
We've now got working R33 tuning boards available, will have the Nistune update from Matt this week to see how the nistune software goes with the RB25, can't wait...
I'm using NRE from the same guy who wrote LiveEdit but full real time map tracing and emulation...
R33 Remap - Example
Standard R33
FMIC
040 Fuel Pump
3" Turbo Back Exhaust
HyperGear TR43
STD AFM
STD Inj
STD Air Box
Remapped R33 ECU - 45 mins of dyno time
More to come with upgraded injector and afm
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3335522
At the moment they are quite expensive, and yes quite difficult to install, would only recommend advanced electronics techs attempt this, need smd experience and equipment... I'm still trying to work things out regarding fast turnaround of supply and install with base maps...
Edited by Dr_Drift
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3335675
Hey Guys
Good to hear news is spreading.
And sorry for the no reponses to email. Just found out last week that AAnets mail server has been really dodgy and not passing on emails... and I just thought it was getting a bit quiet until Pete L told me customers were able to contact him through his site.
Not happy but not much I can do now until they fix it!
Please contact me [email protected] in the meantime if you wanted to know any thing about the boards or place an order etc.
thanks
Matt
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3362228
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
