Hey Guys i am from SA and i am about to purchase a GTR from Melbourne. I would like to have it inspected by a trusted and recommended workshop. I have already read the list of workshops though i would like to know about personal experiences with the workshops.
Any help will be much appreciated.
https://www.sau.com.au/forums/topic/182227-which-workshop/
I havn't read any lists anywhere but the best (and only) inspection i had done was by racv, they picked heaps of little repairs that i couldnt find till it was pointed out to me and anything they said was worn and about to break broke in 6-12 months, they are also very detailed with there reports, would definately get another one off them again.
https://www.sau.com.au/forums/topic/182227-which-workshop/#findComment-3310228
Depends where the car is located
Eastside/southside any of the above, but i wouldn't take it to racv. Yes RACV can spot the obvious (to a trained eye) but will they do a leakdown or compression test? Do they know how a good GTR handles and preforms?
Northern/Western suburbs i would take it to EAS Performance; refer to my sig below
https://www.sau.com.au/forums/topic/182227-which-workshop/#findComment-3314821
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
