  • Replies 241
Posted Images
yeah not wrong Joel
hey ill drop what im doing sat evening to come and help you get it in if thats all thats needed ... plus delivery of the thing :whistling:
wheres it coming from did they have it in stock so many questions :P
yeah not wrong Joel
Clutch is from Kudos Motorsport (did an awesome price on an exedy gtr 3puk ceramic) I doubt it will get here by the weekend but fingers are crossed.
Putting the box in isn't a hassle, 2-3hrs max; getting it out of that pranged rb25 was a massive hassle due to that slightly compressed tunnel. :D
Ohhhhh! I think I may be back up for this!
I finish with the Bay to Birdwood at around 11 and since I'm assisting with the start I'll be right around the corner from the first departure point for the cruise!
Put me down as a probably maybe Steve lol :D
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
