if you'd like to live a normal life in australia, or something close to it, you'd want a work visa. It allows you to work for up to 6 months with an employer (after which you just change employers) on a part time or casual basis. You're allowed to drive on an international license for 3 months I think.
Most people who travel with no work visa do cash jobs and no paper trail... but then you won't be covered by OHS laws etc if something happens to you at work.
Talk to your local Australian embassy, they should be able to give you all the options, paperwork etc.
After your year is over, you can fly back, apply and come back. Basically you become an illegal immigrant after overstaying your visa :thumbsup: you get taken out to a detention camp in the middle of the australian outback, stripped and raped by big samoan/maori guys.
ok maybe I made that last bit up, they don't strip you.
im looking at realestate.com.au and have found some decent priced homes.. but there are thousands of communites and i have no idea which is closer than the other in relivance to living close to Downtown but not in downtown.
for example.. how close is hornsby to downtown sydney compared to gosford?
WA is the go, come to sunny WA. :banana: Much closer than the Eastern States :down: you betcha.
Cheers GW
waits..................logs out.
Edited by 260tech
yes he means western australia, but nsw is where its at :)
Like the man says. Western Australia.
Seriously, best thing to do imho is 1. Check out Oz Embassy in your area with your legit questions, 2. Find suitable job or job prospects in OZ at preferred location/state capital. (www.seek.com.au) 4. Look for accom in the area in which potential job(s) is.
Done.
Cheers & good luck. GW
PS: Major No-no to try to screw immigration authoritys around. Very bad move. Could be fatal.
PPS: If you have trade or tertiary skills (too lazy to read all of thread) WA is screamin for people to join the work skilled force. Could maybe get sponsored after trial period. You never know.............
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
