hey guys i was just wondering
i have a 1993 32 gts4
and was just wondering , if taking the fuse out for the 4wd system in the car will or could screw anything up, for long periods of time.
just a general question that i was thinking about
if anyone could answer this for me that`d be great
cheers
https://www.sau.com.au/forums/topic/182650-gts-4-question/
so skybarge and adam u guys both have GTS-4s?
and do uz run em in rwd? or just keep to the 4wd?
coz i really didnt wanna screw anything up lol.
lol ABS stops working wow lol, thats pretty bad lol, wud it screw anything up if everynow and again i kept changing from 4wd to rwd?
thanks heaps guys
https://www.sau.com.au/forums/topic/182650-gts-4-question/#findComment-3315149
you realise that an R32 GTS4 or GTR is always switching from 4wd to 2wd by itself?
they are 100% rwd until slip or enough Lateral forces are placed on the car to push some torque to the front wheels.
Look at your torque split gauge on the dash when you are driving.
if it is sitting at 0 like when you are crusing along etc, it is in rwd.
just get the switch.
there is nothing wrong with going 4wd to rwd.
https://www.sau.com.au/forums/topic/182650-gts-4-question/#findComment-3315224
So the GTS4 has ATESSA just like the GTR? I always thought they were a constant awd. Looks like I was wrong.
And yes its true what GTST says that the GTR's are 100% rwd until slip/lateral forces etc.
Huh, learn something new everyday.
https://www.sau.com.au/forums/topic/182650-gts-4-question/#findComment-3315298
the pulsar GTiR has constant 4wd... people have long been saying they have attessa etc but they are constant 4wd.
GTS4 and GTR in R32 form are 100% rwd until they loss of traction or enough forces to push torque to the fronts.
GTS4 and GTR in R33 form have always got like 10% going to the fronts and it increases with traction/forces.
R34 GTR is similar to R33
https://www.sau.com.au/forums/topic/182650-gts-4-question/#findComment-3315406
The stagea has the exact same attessa system as the GTS-4 and it isn't a real good idea to drive around in 2WD all the time because you can really stuff the clutch packs in the transfer case.
The problem is, due to the pre-emptive nature of the attessa system, the front wheels are never completely without drive, (as the stagea is based on the R33) even if no torque is being transfered as per the gauge readouts. If you do a search in the stagea section you will see that the general consensus is the only way to run 2wd is to drop the front driveshaft. We have a member that tried to just drop the fuse for a 2wd dyno run, and the whole car ended up full of smoke from the clutch packs in the transfer case. :thumbsup:
https://www.sau.com.au/forums/topic/182650-gts-4-question/#findComment-3315536
thanks heaps guys
Yep :thumbsup: I own a 1989 GTS4 one of the earlier ones, I run mine in 2wd mode quite a bit, just for the hell of it, it drifts nicely, not quite as good as a T because it's heavier but yeah,
And it is the same system that the GTR uses >_< as GTST says above, the GTS4 is in RWD mode a lot of the time, try flinging it into a corner(when no one is around and preferably on a closed road or driveway) and you'll see that it slides nicely for a few seconds then the FWD will kick in and you'll get a lot of grip
I'm not too sure about the Stagea, I always thought the R33 GTS4 & R33 GTR, Stagea all versions and the R34 GTR didn't like going in with the fuse pulled because the weren't using the same clutch system as the 32 model and their clutch packs start to wear...
https://www.sau.com.au/forums/topic/182650-gts-4-question/#findComment-3315567
I run my car the way it was built. Like GTST has explained, it's RWD most of the time when I'm cruising and it only gets into 4WD mode when the front start to lose traction or when I'm pushing the car a bit ( not that I've pushed my car before, bit hard being on Ls).
The 33's and 34's aren't as easy to make it into RWD for some reason. I can't remember why though. :pwned:
https://www.sau.com.au/forums/topic/182650-gts-4-question/#findComment-3316157
32 gtr and gts4 can have rwd only and abs active, pulling the fuse in the engine bay kills power to the attessa motor.
Pulling the fuse in the drivers cab kills power to the attessa module, which is also the abs module, so both go..
33 and 34 gtr, gts4, stagea, all have an attessa system that has a small amount of hydraulic preload on the transfer case clutch packs, so you have a small percentage of torque to the front wheels at all times. This combined with the faster sample rate results in a faster response in torque transfer to the front wheels, compared to the r32 version.
I quite like the nose heavy, tail happy attitude of my car in rwd.. :blink: reminds me of my old ute. only in the dry though, damn dangerous in the wet. 4wd in the wet is like rwd in the dry.. Sooo much of a difference.
https://www.sau.com.au/forums/topic/182650-gts-4-question/#findComment-3317072
Awesome :P I'll be changing my switch to the front fusebox then, well maybe i"ll have two switches:
one connected to dash fuse - for doing burnouts and warming the tyres prior to drags
one connected to under bonnet - for general RWD fun and daily driving
Yeah I love the feeling too, being that much heavier than the T and the front end being a few kg heavier it's much easier to hold the drifts and it just sits there, although it does drift a lot slower than my T, so I won't be using it on the big drift circuit, only the local drift track we have here
I quite like the nose heavy, tail happy attitude of my car in rwd.. :( reminds me of my old ute. only in the dry though, damn dangerous in the wet. 4wd in the wet is like rwd in the dry.. Sooo much of a difference.
https://www.sau.com.au/forums/topic/182650-gts-4-question/#findComment-3317407
Instead of tapping the fuse for a switch as most people do, you can also tap the wire inside the cabin near the ECU. ATM I've got a switch next to my hazard that I can flick to choose to go to RWD. It dosen't harm the gearbox in short doses as the R32 transfer is hydraulic, and not partially engaged like the later models. This means that the R32 ATTESA is a lot laggier, but hey, thems the breaks.
I tend not to leave it in RWD mode as ATTESA is a beautiful thing when driving normally (ie not sideways or on a drag strip etc).
I'm currently playing around using a jaycar digital pulse modulator (also about $50) to vary the signals sent to the ATTESA computer so I can fine tune how it reacts, and also do a RWD->AWD->RWD transition without having to stop the car or lose ABS... without resorting to a potentiometer style knob or a ATTESA interceptor that costs an arm and a leg.
https://www.sau.com.au/forums/topic/182650-gts-4-question/#findComment-3317418
Yeah i was thinking of doing something similar, but using the potentiometer, it's just the costs that are setting me back at the moment :(
Would love to turn it up to like 30-40% Front bias in the wet though and not have to worry about it stepping out slightly when I kick the throttle
https://www.sau.com.au/forums/topic/182650-gts-4-question/#findComment-3317475
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
