  • Replies 67
I have PM'd v-spec as i have my mate (Chris) who wants to come down and wants a bed....
Apparently there is about 4 people in v-specs list that are wanting a cabin......
My accomadation has been organised with one of my passengers' relatives.
OK... this is getting confusing.......
PLEASE POST IF YOU STILL NEED ACCOMODATION. I have a mate wanting to come, so wondering if there is anyone left, i can throw him into a cabin with.....
Otherwise i will just try and organise a cabin for me and him.....
FFS how hard is this shite...........
Or alternativley if someone has a spare bed in their prebooked villa/cabin, let me know please so i can tell my mate..
If you are staying at the eagle hawk you will go past the sutton road exit on the highway (big blue mark on the map) and the next turn off is to get to where you are staying (Red mark on the map). if you are going to the pub/club thing someone was organising in Queanbeyan your best off following sutton road south to the end (you will go past the sutton road track/skid pan complex) and taking a left and that will take you into Queanbeyan for thoes of you that have never been before.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
