I'm going to be changing my gearbox and diff oil this weekend and I've read really good things about Redline Shockproof.
What type do I want to get for my gearbox and diff? Heavy or Lightweight?
I got quoted $115 for a 3.8 litre bottle from "Performance Wholesale" at Slacks Creek (Brisbane). Does this sound right? Will this be all I need? I read somewhere that the gearbox takes 2.4 litres and the diff takes 1.4 so it should work out ok. Can anyone confirm?
Edited by Simmo1985
https://www.sau.com.au/forums/topic/183077-which-type-of-redline-oil-to-use/
I was told that shockproof will make the LSD shudder a bit. I used lightweight shockproof in the front (open) diff and gearbox, and redline 75-90 in the rear diff. Just make sure that whatever you get for the rear diff is LSD friendly. Also, you should use a GL-4 in the gearbox and a GL-5 in the diffs.
what do you guys recommend for a Cusco 2way? and shock proof for the gearbox.? light or heavy? the 2nd and 3rd are a bit crunchy when cold..
Lightweight shockproof is often recommended for tired R32/R33 gearboxes. Dunno about the diff - ask Redline for a recommendation here
  • 3 weeks later...
i recently put redline heavy duty shock proof (i think thats what its called) in my gearbox. i havent felt any shudders so to speak but it is a little bit more difficult to shift into gear. espcially 1st when it is cold.
is this normal? my mechanic said this was the best stuff around.
i use ls140 with ford motorsport additive in my kaaz 2way so i dont see why it wouldnt work in a cusco. as for gearbox i use 75/90. dont see the point in using expensive shit when i'll only change it in 30,000kms
The point is;
- You'll be better protected during those 30,00kms (and beyond)
- You dont have to change it until you get to 100,000kms
No its shouldnt be more difficult to shift. The common recommendation is lightweight shockproof, not heavy. Perhaps that's the problem.
Shudders would only occur in LSD diffs, not gearboxes.
Sorry i didnt get the shudder and diff connection
yeh well it definitly is alot harder to push the gearstick into gear. but like u say it is probably because its a more viscous oil.
other than that it is alot smoother since i changed the oil.
    • Oof. One of my mates has an R34 GT-R that he initially was a "I want to go twins for response and convenience" on his stock 2.6 with Kelford 272 cams, but his friends are pests and were always in his ear about their place being in the bin.   Eventually one of the 2860-5s decided to add it's own input and force his hand, so he conceded and went for a Pulsar 6262G ("G35 900") with T4 0.85 hotside.    Here's an overlay of the results, same cams, same stock bottom end, same boost, same fuel, just from a pretty tidy 2860-5 install to a Pulsar turbo on a 6boost maniifold on BP98.   Worth mentioning here, it may seem like a dead horse thing but the dyno plot doesn't tell the story of how much better it is to drive - transient response has completely changed the car, he used to have flat foot shifting to stop it having to wind up again on gear changes even at >7000rpm... now it builds boost faster than that even short shifting.   It's 100% transformed the car before you even consider how much better it holds on: Pulsar and Garrett aren't the same, but from our experience if you're just looking for a better drive and the ability to make the same or more power I think the divided G30 770 would probably be the smallest I'd go to.
    • Great work Duncan, any events local you will give it a test once all done?
    • Sweet, yeah hoping stock gears will hold up. May use the transbrake feature on hill climb starts so that will test it.
    • Yeah, the thread is only nearly 20 years old.
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
