CAR IS SOLD, THANKS
Hi all,
Up for sale is my blue merc. It is an immaculate car and I planned on keeping it once I sold the white one but I need to sell it due to financial difficulties.
I am the second owner of the car, and prior to me purchasing the car it had been in storage for 12 years. The guy that had it before me serviced it with Mercedes.
The interior is immaculate, the engine runs beautifully and it is reliable, I have taken it to the coast and to syndey and it didn't miss a beat.
I have spent some money on it, new front shocks, calipers all rebuilt, new bushes, gearbox service, carburetor rebuild, other bits an pieces, painted the roof in blue candy and lined and scrolled the car.
For the age there are few cars around that run as good and in as good as condition for the money.
Asking $3000 ONO
phone 0418 327 427
Edited by Fitzpatrick Speed Works
https://www.sau.com.au/forums/topic/183250-ol-skool-merc-take-2-sold-sold-sold/
Thanks Christian,
Car has genuine 260XXX kms on it as varified by mercedes service papers. It is a 250 optioned with air con, 1974 model the last of the 114 body style.
Tranny is auto naturally most mercs are, with the manuals being very rare and a pain to get parts for, auto is the go for a cruiser like this.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
