Old topic.
Well like it sayd on the thread Will the GTRs exhausts fit onto Rs4s and 260Rs? And exhaust from Rs4s are interchangeble with 260Rs?
I know in terms of length wise the Gtrs exhaust will fall shorter in comparison to the Rs4s and 260Rs specs. Cos i noticed in my Nismo exhaust from the end of the main body of the muffler to the tip of the outlet exhaust its like almost a foot long. Probably its just a GTrs echaust with an extended tip to fit onto the 260Rs.
Main thing is are the hannging points where the exhaust are hooked onto the undercarriage vis a rubber thingy are all at the same points? With the Gtrs, Rs4s and 260Rs? If they are almost the same then it shouldnt be a big problem to modify it abit. And how about the layout the bends of the exhaust ETC all the same?
https://www.sau.com.au/forums/topic/183304-gtrs-exhaust/
Old topic.
Main thing is are the hanging points where the exhaust are hooked onto the undercarriage vis a rubber thingy are all at the same points? With the Gtrs, Rs4s and 260Rs? If they are almost the same then it shouldnt be a big problem to modify it abit. And how about the layout the bends of the exhaust ETC all the same?
Hey I tried a r32 exhaust on my rs4 as thought i would be able to lengthen it as some other forum members have done. Problem I had was that the offsets for the rear muffler on the r32 were centre to centre, where as the stagea really needs right-right. I couldn't get it to fit in, and the pipe bends weren't quite right either.
I have a Trust Power Extreme system specifically for the stagea that I am looking to sell as it hangs a bit too low at the rear can for my stupid-steep driveway. PM me if you are interested ... looking for $750 but need to sort a replacement system first. Its only been on the car 2 weeks.
https://www.sau.com.au/forums/topic/183304-gtrs-exhaust/#findComment-3322528
Are the echaust for 32s, 33s and 34 GTRs the same meaning are they interchangable? Are the Rs4s and 260rs exhaust interchangeable?
I can confirm that the dump and front from R33GTR can be used on 260rs no problems. But cat back i dont know. Any ideas?
What im trying to do is try to use an echaust from R33 or R34s why? Cos theres not much to choose from a 260rs for the exhaust system. Im trying to look for a 3.5" at least. So....
https://www.sau.com.au/forums/topic/183304-gtrs-exhaust/#findComment-3322893
I have tried to fit ( well lined up ) a skyline rear box on a Std RS Four. The petrol tanks appear to be in a different position.
There was no way it would fit .
Skyline GTS exhausts dont fit GTRs so I would assume that RS Fours AND 260RS exhausts are different. Possibly the back box may be the same shape but could be a different pipe size
Edited by RSVFOURUK
https://www.sau.com.au/forums/topic/183304-gtrs-exhaust/#findComment-3323993
did you sue a Gts box or a gtr box? Im tryin to use a GTR echaust on a 260rs though
https://www.sau.com.au/forums/topic/183304-gtrs-exhaust/#findComment-3324302
you know you can fix your steep driveway easy. Go to the junk yard and buy your self a tick steelplate and put it over the ditch so the angle becomes not so steep. of course you have to drive a few bolts on the pave way to hold it in place. Seen it in a few service station and coles did it.
Yea ken im looking into buying one from japan.
A friend of mine told me that Rs4s and 260rs are interchangeable. And 260rs can use a Gtrs echaust but have to cut and weld though. I think i will just have to do that
https://www.sau.com.au/forums/topic/183304-gtrs-exhaust/#findComment-3327856
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
