on the way home from work tonight i was driving my gfs car.... heading away from the casino towards the albert park area and some asian guy in a Silver 33 with blue neons under his car and other ricey accesories pulled up at the lights next to me revving the hell out of his engine... had a zorst and running more boost from the guage i could see... ignored him at the lights for a while.. he kept revving it up.... so i thought... fark it... i'll see what this can do.
*click*
takes off traction control
*click*
puts it into power
left overdrive on...
lights go green and he plants it... slightly wet roads he starts spinning them up... i take off half throttle... haha im ahead... what a n00b p plater... we've travelled about 10ms now and im still ahead so i plant it to the floor... auto kicks down a gear... nose lifts... exhaust starts screaming like a male banshee with his balls in a squirell grip thru a 20" subby with the bass on +6!
bahahaha im pulling away from him... 100m later he isnt gaining so i slow down and start breaking... he keeps going lol yeah u keep going... i would too... how embarassing.
https://www.sau.com.au/forums/topic/18333-maybe-she-will-beat-me/
lol my mate has a soarer GT exactly the same as your gfs (in fact I think he's dragged it at some point in time...) remember? the one with the same rims as what you wanted? And his car hands some major ass out, and its pretty much the same as u'r gf's setup, so i dunno...
anyways... if you back out now i hereby proclaim you:
Inarkus Poultrous
Soarer auto g/b r insane i drove a mates and the instant u floor it, it reaches redline and doesnt even budge even between gears, smoothest auto ever !!! and hes doin 13.8's !!!!! Auto's r often underestimated, work it a bit, enuff coolin and u'll be beatin a lot of manuals on launch all u need is the power to back it up
lol so many times i'll get em on launch but they'll pass me by 3rd, sometimes in 2nd too, :)
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
