Hey all, just got new RDA slotted rotors all round and brand new EBC redstuff pads installed yesterday.
After bedding the pads in they have started screeching like crazy, im talking about almost unbearble screech here.
Under hard breaking they only squeal lightly but pulling up to lights is horrendous.
I dont understand the problem, the rotors and pads are brand new.
Does the surface of the new rotors need to wear in or something?
Any help would be appreciated.
CHeers
red stuff is for track use. so alot of those pads squeak ... dnt think there is much u can do. dont use that squeal remover shit.. i heard it does bad things to performance of brakes
Ahh ffs!
Those pads cost me $400, i got them through a group buy on this site.
surely the GB organizer wouldn't have sold me pads that were unsuitable to everyday driving on the street?
The noise is almost unbearable.
i dont mean to be rude at all but did you not at least look them up to make sure that they were gonna be suitable for everyday use/ to suit your needs?
Well seeing as the organizer new that the car was going to be street driven, and said they were a good pad, no, at the time i didn't feel it necessary to do some research on them.
Now, does anyone have anything useful to add to the thread?
Yes, sell them and buy standard nissan pads.
They do the job well for street.
I had some endless pads and they squeaked like crazy!! so i just ended up selling it
hm.. ive been reading about applying anti squeal grease to either sides of the shims, and that this sometimes eliminated squeal.
I'm not just going to give up and sell them seeing as i paid $400 for them.
If need be, ill keep them and use them as a track pad if i ever get to one of the QLD raceway track days.
Ahh ffs!
just think of all the fagots with convertables your going to piss off :)
i do it every day as i've got project mu level max 900 on the fronts and similar on the rear. makes alot of noise
also if you wish to make the a little bit quiter. i beleive you can file away the edges to make them slope down towards the metal backing plate and that will reduce the noise a bit.
Edited by Angus Smart
I have the exact same combination of rotors and pads on my gtr and they hardly squeek. Don't know whats happening with yours mate, but after a short while you will notice that they are not very good from cold and you will need to warm them up a little for them to bite. I won't buy these pads again.
The advise to search for threads to remedy to this problem is a good one. Do a quick search on the site coz i was reading extensively on this a few days ago. Forgot which thread exactly but lots of techniques were described to quieten squealing brakes and apparently most of the time it comes down to piston to metal backing plates on the pads rather than rotor to brake lining friction...or so someone was saying so yeah, just look it up. I have endless CC-X pads on standard albeit resurfaced rotors on my GT-t and they squeal but it's not so bad so it seems to come down to how they were fitted because everyone seems to have different results which does not coincide with the combination of rotor/brake pad.
Good luck
yeah search will give u much more info but to break it down
chamfer leading and trailing edges on brake pad
scuff up brake pad surface with 80 grit sanpaper
use anti-squeal compound on the shims (you do have shims,dont you??)
lubricate all pins etc that need it
machine rotors, or in your case you have new ones
bleed the brakes
do a good bed in session to get them really bed in
thats about all i can think of but yeah i have the same problem (different pads tho) and after about 2 weeks they settled down on their own
damn brakes!!!!!!!!!!!!!!!!! lol good luck
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
