Sup all,
Have a small problem perhaps you all can help me with??? I have a sticker baked on my car's duco, does anyone know of a way to remove it easily and without removing the paintwork with it?? all advice is appreciated ... :)
Edited by immortal^
explain baked on? as in it was a normal sticker which was put on the duco and then through heat from the sun is stuck on?
if thats the case, use a hair dryer to heat the sticker up and make it plyable. then using a rag, rub hard and break the sticker up, then using a cutting paste, cut and polish the area to remove the sticky residue.
Yeah pretty much as you said cheez... normal sticker gone hard over time due to nature.
Thanks cheez, ive heard that before I will try it, needed someone to reafirm my ideas, cool.
get a hair dryer.... heat over the sticker for a couple of minutes... then buy yourself a bottle of Eucoliptous oil (hope I spent it right) and with a small tower... start to crub it off slowly - it will come off!!
Like they said use some heat, but I prefer to use a toffee wheel to remove the glue, its a rubber wheel that fixes to a drill, use it on a slow high torque setting and it takes it off with out using sometimes dangerous chemicals, really really good product!!
Your find them on ebay:
http://cgi.ebay.ie/Eraser-Toffee-Wheel-Pad...oQQcmdZViewItem
Edited by DriftyR33
step 1,,,,,,,,borrow a heat gun, apply heat, not to close, then start to peel with your nail, if you know any panel beaters,painters or house painters, they will have one, or buy cheap one from bunnings,
step 2,,,,,,use a wax and grease remover to remove the glue thats left on panel,
step 3,,,,,,polish, as will be a shade diffrence around where sticker was,
step 4,,,,go into panel shop, get them to do it, a sat morning best and slip them 10 bucks, only takes 5 mins to do if you have correct tools
thats some shithouse english right there....
seriously though, ive used a razorblade to do it many times and it works a treat. i know it sounds dodgy but if u have half a clue as to what you are doing you will easily be able to take off the adhesive without scratching the crap out of your paint
that sucks. i used to be a detailer for about 4 years. the way we used to do it is with a heat gun then peel it off in sections. use a bit of preptone or prepsol. then cut and polish it. if its baked on, trust me when i say your always gonna see where the sticker was on your duco
good luck
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
