Sup all,
Have a small problem perhaps you all can help me with??? I have a sticker baked on my car's duco, does anyone know of a way to remove it easily and without removing the paintwork with it?? all advice is appreciated ... :)
Edited by immortal^
explain baked on? as in it was a normal sticker which was put on the duco and then through heat from the sun is stuck on?
if thats the case, use a hair dryer to heat the sticker up and make it plyable. then using a rag, rub hard and break the sticker up, then using a cutting paste, cut and polish the area to remove the sticky residue.
Yeah pretty much as you said cheez... normal sticker gone hard over time due to nature.
Thanks cheez, ive heard that before I will try it, needed someone to reafirm my ideas, cool.
get a hair dryer.... heat over the sticker for a couple of minutes... then buy yourself a bottle of Eucoliptous oil (hope I spent it right) and with a small tower... start to crub it off slowly - it will come off!!
Like they said use some heat, but I prefer to use a toffee wheel to remove the glue, its a rubber wheel that fixes to a drill, use it on a slow high torque setting and it takes it off with out using sometimes dangerous chemicals, really really good product!!
Your find them on ebay:
http://cgi.ebay.ie/Eraser-Toffee-Wheel-Pad...oQQcmdZViewItem
Edited by DriftyR33
step 1,,,,,,,,borrow a heat gun, apply heat, not to close, then start to peel with your nail, if you know any panel beaters,painters or house painters, they will have one, or buy cheap one from bunnings,
step 2,,,,,,use a wax and grease remover to remove the glue thats left on panel,
step 3,,,,,,polish, as will be a shade diffrence around where sticker was,
step 4,,,,go into panel shop, get them to do it, a sat morning best and slip them 10 bucks, only takes 5 mins to do if you have correct tools
thats some shithouse english right there....
seriously though, ive used a razorblade to do it many times and it works a treat. i know it sounds dodgy but if u have half a clue as to what you are doing you will easily be able to take off the adhesive without scratching the crap out of your paint
that sucks. i used to be a detailer for about 4 years. the way we used to do it is with a heat gun then peel it off in sections. use a bit of preptone or prepsol. then cut and polish it. if its baked on, trust me when i say your always gonna see where the sticker was on your duco
good luck
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
