I've found something i am rather interested in. but it doesnt look right... compared to the other prime edition stageas i've seen on the web
why is there no sports style shift?? is this a different version from prime edition?
cheers :D
Edited by Angus Smart
https://www.sau.com.au/forums/topic/183446-possible-stagea-purchace/
cheers :D
Yes, some series 2 Neo Stagea's do not have the tipronic gearbox
Cheap base model car. They are not very common.
I would not buy it for that reason
I just had a closer look. That car is a series 1 (black dash dials, not white), so it it would not have a tipronic anyway
But my last post is still correct, very few series 2 did not have tipronic either
Did some more searching
Here is another series 2 with No tipronic, but with black dials
So my second post was wrong about it being a series 1
Maybe some of the first series 2's, nissan was cleaning out the series 1 auto gearbox cupboard, until they swapped over to the tipronic gearbox?
http://www.skylinesaustralia.com/forums/in...2&hl=stagea
Yeah - I have seen a very similar bastard child S2 tha had no triptronic. It did have the white faced gauges though, and it also had the Neo engine so I have no answers for you there. I can say that the one I saw I would still consider because it had a very unique level of trim and some very nice bits 'n pieces (Dayz bar, among others)
If you like the car then just evaluate it on its own merits, not wether it has everything a RS4 has. You may even save a few bucks on it and it would be a great base for a manual conversion later on.
hmm can we call it a S1.5 stagea? (joking).
I'm assuming it does still have the NEO engine?
but no transmission oil cooler? (guessing).
I cant imagine resale value of these models being any higher than a standard S1. Just my opinion though.
looks like a 25x series to me which did come with leather and wood satnav etc but black dash and no triptronic there was a red one on jpsec for about 12 months like it...............http://history.nissan.co.jp/STAGEA/PAGES/MC0831/index2.html
Mike is absolutley correct!
This is a 25(t) X FOUR with optional olive grey leather (heated) seats. (velour was standard)
It has the optional Momo Wood combi steering wheel
All the X & G series came only with the E-ATx box (non tiptronic)
This is NOT a prime edition.
Is it a 98 model....they seem to have different front grill compared to S1 and S2 versions. This may be the case for the car you are looking at. Pretty sure these ones do not have the NEO RB hence no tiptronic.
EDIT: Just saw post #6 about 2000 model.....there goes my theory blown out the door. :P
Edited by Topkart R33
The grills with the bars in them are the lower-grade X- and G-spec models. This one below is a WH-C34 20G, which means it has an RB20DE and auto box. The series 1 version of the 20G didn't even have DOHC - how much would that suck! A two-litre, single-cam, automatic struggling with the weight of a Stagea...
More information...... HERE!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
