Hi Mate, auto starts are suppose to be ilegal or some shit, but i have one, it only works from the button.
My allarm need the car to be in Neutral and hand brake on before it activates. When activated, if the key is not inserted in 15 seconds, or the brake or clutch or gear pressed/selected, without the cey the car shuts off, goes into alarm mode and won't let you start it unitll you desable the impboliser.
It is great for freaking people out. My also has the output to turn a heater on but the R33's don't have a secondary heater input.
The alarm allows up to 8 minuts of preheat time, but i haven't changed this yet.
ALSO if the car is started ad droven away by somone, if they are within range, the alarm will switch the motor off from the key aswell.
It's more wenk factor, but essentially it was there so we made it all work.
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3324740
Not sure what brand mine is, and i do agree it is ilegal and if stuffed up, propably bad too, like starting in gear and so forth.
I'm not sure about the easie to get arround part. My alarm has 3 points of imobolisation and 3 poits of auto start, esentially making it 6 poits, as eaven without autostart, all the correct points need to be deactivated to start the car.
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3325936
paolo,
on auto cars I'm not biased - I WATCHED a MANUAL VEHICLE start and PIN a 5 y/o girl TO A WALL - I have a REASON for stating what I do. I was not responsible for the work on that car but I knew FULL well how it happened. it had a makeshift neutral safety switch that failed - car was IN GEAR and it started.
they are good for warming up or cooling cars off on seasonal times but not much else. I see it as a 'look at me ' thing.
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3329591
on my mates car he hit the remote start button, car kept on cranking but wouldn't start, we walked over to see what was going on and BANG? it backfired from all the fuel, back out the intake and blew the side out of his custom plenum.
i've also heard of them doing damage to starter motors.
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3329678
depends, on a diesel the car will start and drive off. (mate of mine did this as a joke in an open field with him in the car.)
in the case I saw it was a case of wrong place right time. car moved and pinned the kid!
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3339775
the car cant move when its activated in gear..
it will just stall? Chris?
Hey...........
The only car that will not move is an automatic or a car with a neutral detect switch.
Every other car will start and move or atleast jump then stall
Dont kid yourself..
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3340694
further proves your 1 track minded views on everything in a negative fashion. list some pros.
1 track mind?
I thought he just specified it can be DEADLY if not wired in correctly or if there is a malfunction. What pros are you looking for when the damn thing is a potential death trap?
And how do you people think a remote start actually starts the car? Well let a professional explain it to you.
In order to crank and start a vehicle you need to have 12V across the ignition wire, and 12v for a short period around 1-3 seconds on the starter wire. Once you have these two, the starter will turn the engine over, and the ignition will ignite the fuel. CAR STARTS.
Now what makes you think that your car is now not easy to steal? Where do you pick up your ignition and starter points? AFTER YOUR IMMOBILISER, otherwise its not going to work. So you have just given a thief an easy way to HOTWIRE YOUR CAR just by looking at your aftermarket wiring. Your immobiliser and your remotes are now useless. All someone has to do is crank the car start and drive off. Your remote which claims a KM distance has actually just been diminished to 200 metres due to buildings and trees and what not because it work on an FM band.
Dont kid yourself there is no PRO'S to a remote start alarm.
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3353340
1 track mind?
Well said!..
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3356975
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
