Ran it tonight..went well only ran it on low boost (21psi) to "shake it down"
I finally reached my 20th run tonight so still very much a novice.
So here's what happened...
1st pass 1.60 60' short shifted all gears and ran 10.7 @ 130 MPH
2nd pass 1.49 60' gave it a bit more in each gear and ran 10.4 @ 134 MPH
3rd pass got hassled at the start line about only having 1 arm restraint and forgot to switch it back into 4WD (this was my last run as they would not allow another pass without both arm restraints fitted). Launched it off the limiter and lit it up spinning the rears (2WD) past 60' (1.90). But really put the foot down in 3rd and went through the traps for a new MPH PB of 137 MPH. Across the line both belts (power steering and alternator) came off and tore a huge hole in my top radiator hose. Thus ending the fun for the night.
When its fully tuned with full boost and a driver with a bit more experience this things gonna be awesome.
The car now weighs 3030lbs or 1375kg...but, im still over 100kg.
  • Replies 682
Nice MPH and car weight, you must be stoked.
Chris, even when i had busted the radiator hose and the night was over for the car i a had a smile on my face and was very impressed with the potential of the car.
Yes i was "stoked" :thumbsup:
well done Pauly. Pond and I are proud of you and Twoogle. :worship: Next time I will be able to come and cheer you on.
Stace xx
Congratulations, sounds like its going to be a winner!
RH9 club?
Thats the idea...9's on radials.
no one's done it B4 on low mounts...let alone with synchro box and a Power FC.
We still are yet to connect the Nitrous set-up as well.
Im very happy with the progress so far.
Very nice!!!!
Who said the power fc is a crappy computer ? :thumbsup: are you running AFM's ? or map sensor version?
Hope you crack the 9's without the cheating gas.. Will be very impressive when you do.
and here i was thinking rh9 had to include twin low mounts...
thats awesome!
whens the next outing?
thats awesome!
Running AFM version of Power FC
Looking to run at a private track hire on Saturday.
in this thread http://www.skylinesaustralia.com/forums/in...howtopic=185614 you said
you said you had a SM4 plug and play with MAP sensor..
different cars I guess.
I said "yes we have one"
but...not installed yet
this car goes back a long way that i can remember. Good to see its still going well.
Its an oldie but a goodie.
Car was originally a 1st Anniversary wedding present back in 2001.
1st anniversary present is traditionally paper...Stace got paper...rego paper.
some data on the 10.4 run...the g-tech was not calibrated correctly so the ET's a little off (0.2secs) but the MPH was spot on
as you can see above, the shift point was set to 9000rpm...i didn't see or activate the shift light for the middle of the run and shifted 1-2 at 8400rpm and 2-3 at 8600rpm
EDIT: just replay'd the run and the shift light only came on going across the line (top of 3rd)
the graph below is speed vs time
the car does not accelerate for 0.4secs on the 1-2 change and 0.5 on the 2-3 change, much improvement is to be had there. Very lazy changes and need to rev the car a little harder through the gears.
EDIT: be kind with your comments 2rismo
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
