Yeah but Mark tunes in 4th gear so its not a direct comparison. Good luck tomm. who is crunching the numbers?
EDIT: ohh i see where you are coming from...pick both the Mark tuned 22-25psi runs out of the dyno computer...got it.
Unigroup, you cant say no to the Autronic experience and neither can I
Yeah ive got a figure in my head, will go to 2bar if needed to get it as long as nothing goes wrong.
  • Replies 682
i hope thats racefuel...i strongly recommend not exceeding 24psi on pump.
Im glad your going to Yavus...he's a gun Autronic tuner.
Edited by DiRTgarage
All pump all the way
Jungle juice isnt my sort of thing, yet.
From looking through as many GTRS graphs as i can find on the net its going to be a 22psi tune that gets me the right number, have to remember though;
-Not the right port job on current head for huge numbers, its more for response
-Quite possibly bad choice of cam profiles
-Increased capacity *Throws up RB30 gang signs*
Very happy though that you paved the way so to speak with the low mounts
you know i will help you when and where i can.
Much appreciated Paul, as always :/
Paul is the kind of guy would would bend over backwards for anyone and then tell you that it was nothing to him for helping you out when you say thankyou.
Thanks for going out today and doing that for me Paul, I did not expect it and I still cannot believe you went out of the house for me, also the assistance you you gave when I was tryin to get my car ready for power cruise was a very big help. If it was'nt for you and Wayne @ Hunter all wheel dyno then i would not have been ready for power cruise.
Thanks mate. Keep up the good work.
Hey..no problem mate...just had to hold my nuts while i was standing or walked. Im not as much of a karnt as i portray myself as...im more a cheeky larrikin with a good heart...who loves his family, his mates and his cars. Ill help anyone out as long as i know they will appreciate it when the job is done. Hey ive even done engine builds for next to nothing to help a guy out....no problem.
Its true, you are a nice guy Paul :)
Can you help me out with a free engine build? - I would really appreciate it :/
(in all seriousness, its good to hear youre ok and that your "gentlemans region" is all still intact).
You break it first then we will talk. :P
Its a pity you wont be seeing it in action at Powercruise (engine) but im sure there will be plenty of footage, it will be one of the loudest RBs there :/
2rismo is going to organise me wheelchair access. what day is best...Saturday?
Who's will be the loudest? yours? lol
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
